CyberHome CH-DVD 300 Back Panel Replacement
  1. CyberHome CH-DVD 300 Back Panel Replacement, Top Panel: step 1, image 1 of 2 CyberHome CH-DVD 300 Back Panel Replacement, Top Panel: step 1, image 2 of 2
    • Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD.
    • Unplug the DVD player from the wall socket.
    • Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
  2. CyberHome CH-DVD 300 Back Panel Replacement: step 2, image 1 of 2 CyberHome CH-DVD 300 Back Panel Replacement: step 2, image 2 of 2
    • Remove the top panel of the DVD Player by:
    • Sliding the top panel backwards.
    • Gently lifting the back of the top panel up.
  3. CyberHome CH-DVD 300 Back Panel Replacement, Back Panel: step 3, image 1 of 2 CyberHome CH-DVD 300 Back Panel Replacement, Back Panel: step 3, image 2 of 2
    • Remove the remaining screws on the back of the DVD player:
    • There will be four 15 mm screws and two 6.3 mm screws.
  4. CyberHome CH-DVD 300 Back Panel Replacement: step 4, image 1 of 1
    • Remove the back panel by:
    • Lifting up on the back panel.
    • Pulling the back panel backwards from the DVD player.
Chris Menezes
654 Reputation
5 Guides authored
Cal Poly, Team 6-5, Forte Spring 2014 Member of Cal Poly, Team 6-5, Forte Spring 2014
CPSU-FORTE-S14S6G5
5 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 575
