Cuisinart TOA-60FR Light Switch Spring Replacement
  1. Cuisinart TOA-60FR Light Switch Spring Replacement, Outside removal: step 1, image 1 of 1
    • Using a 25-hexagon head screwdriver, unscrew these three 7.31 mm screws.
  2. Cuisinart TOA-60FR Light Switch Spring Replacement: step 2, image 1 of 2 Cuisinart TOA-60FR Light Switch Spring Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, remove all of these 7.31 mm screws.
    • Pull off the back panel.
  3. Cuisinart TOA-60FR Light Switch Spring Replacement: step 3, image 1 of 3 Cuisinart TOA-60FR Light Switch Spring Replacement: step 3, image 2 of 3 Cuisinart TOA-60FR Light Switch Spring Replacement: step 3, image 3 of 3
    • Flip the oven upside down.
    • Use a spudger to pull out the grey stoppers.
    • Use a Phillips #1 screwdriver to remove all three 11 mm screws.
  4. Cuisinart TOA-60FR Light Switch Spring Replacement: step 4, image 1 of 2 Cuisinart TOA-60FR Light Switch Spring Replacement: step 4, image 2 of 2
    • Unscrew all of the 11.05 mm screws that connect the outer shell to the interior device.
  5. Cuisinart TOA-60FR Light Switch Spring Replacement: step 5, image 1 of 3 Cuisinart TOA-60FR Light Switch Spring Replacement: step 5, image 2 of 3 Cuisinart TOA-60FR Light Switch Spring Replacement: step 5, image 3 of 3
    • Push down with a screw driver between the tabs, then pull up to release the tabs. Pull the top piece off.
  6. Cuisinart TOA-60FR Light Switch Spring Replacement, Light Switch Spring: step 6, image 1 of 2 Cuisinart TOA-60FR Light Switch Spring Replacement, Light Switch Spring: step 6, image 2 of 2
    • Unscrew these two screws to detach the light switch from the panel.
  7. Cuisinart TOA-60FR Light Switch Spring Replacement: step 7, image 1 of 2 Cuisinart TOA-60FR Light Switch Spring Replacement: step 7, image 2 of 2
    • Pull the back piece of the switch off of the clicking piece.
  8. Cuisinart TOA-60FR Light Switch Spring Replacement: step 8, image 1 of 2 Cuisinart TOA-60FR Light Switch Spring Replacement: step 8, image 2 of 2
    • Use a metal spudger to pry open the clicking piece.
  9. Cuisinart TOA-60FR Light Switch Spring Replacement: step 9, image 1 of 1
    • Remove the broken spring and replace it with the new one.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 18
All Time: 484
