Cuisinart TOA-60FR Function Switch Replacement
  1. Cuisinart TOA-60FR Function Switch Replacement, Outside removal: step 1, image 1 of 1
    • Using a 25-hexagon head screwdriver, unscrew these three 7.31 mm screws.
  2. Cuisinart TOA-60FR Function Switch Replacement: step 2, image 1 of 2 Cuisinart TOA-60FR Function Switch Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, remove all of these 7.31 mm screws.
    • Pull off the back panel.
  3. Cuisinart TOA-60FR Function Switch Replacement: step 3, image 1 of 3 Cuisinart TOA-60FR Function Switch Replacement: step 3, image 2 of 3 Cuisinart TOA-60FR Function Switch Replacement: step 3, image 3 of 3
    • Flip the oven upside down.
    • Use a spudger to pull out the grey stoppers.
    • Use a Phillips #1 screwdriver to remove all three 11 mm screws.
  4. Cuisinart TOA-60FR Function Switch Replacement: step 4, image 1 of 2 Cuisinart TOA-60FR Function Switch Replacement: step 4, image 2 of 2
    • Unscrew all of the 11.05 mm screws that connect the outer shell to the interior device.
  5. Cuisinart TOA-60FR Function Switch Replacement: step 5, image 1 of 3 Cuisinart TOA-60FR Function Switch Replacement: step 5, image 2 of 3 Cuisinart TOA-60FR Function Switch Replacement: step 5, image 3 of 3
    • Push down with a screw driver between the tabs, then pull up to release the tabs. Pull the top piece off.
  6. Cuisinart TOA-60FR Function Switch Replacement, Function Switch: step 6, image 1 of 3 Cuisinart TOA-60FR Function Switch Replacement, Function Switch: step 6, image 2 of 3 Cuisinart TOA-60FR Function Switch Replacement, Function Switch: step 6, image 3 of 3
    • Inside of the device locate the function switch and remove the indicated screws (4.97mm).
  7. Cuisinart TOA-60FR Function Switch Replacement: step 7, image 1 of 1
    • Unclip all connections.
  8. Cuisinart TOA-60FR Function Switch Replacement: step 8, image 1 of 3 Cuisinart TOA-60FR Function Switch Replacement: step 8, image 2 of 3 Cuisinart TOA-60FR Function Switch Replacement: step 8, image 3 of 3
    • Rotate function knob to broil so plastic tab is visible when looking from the inside between the switch and control panel. Use screwdriver to push tab down and pull knob out from front side.
    • Remove 2 screws revealed under the front knob
7 other people completed this guide.
TRiels
244 Reputation
1 Guide authored
14 Guide Comments
Anyone have a source for a replacement switch?
Josh - Reply Share
I ordered mine on Amazon
Martin Baumeister - Share
Big thanks for providing these instructions! It worked!
Martin Baumeister - Reply Share
Thanks for the guide. Saved me the headache of having to find a new toaster oven and paying for it.
For those needing it, the part I ordered and used is part model number FZ31-9E (11 pins 7 positions) from amazon.
The switch will also have letters and numbers corresponding to the orientation as in step 6 so keep an eye out for that!
Adam Nguyen - Reply Share
Part of Step 8...Difficult to understand picture how to remove knob on switch? i did follow up instruction that i didn't clear instruction if you have any video how to remove knob from panel switch?
Thanks Todd
Todd Bouma - Reply Share
Past 24 Hours: 15
Past 7 Days: 71
Past 30 Days: 219
All Time: 5,949
