Cuisinart Mini-Prep DLC-2A Button Replacement
    1. Cuisinart Mini-Prep DLC-2A Button Replacement, Cuisinart Mini-Prep DLC-2A Case Disassembly: step 1, image 1 of 2 Cuisinart Mini-Prep DLC-2A Button Replacement, Cuisinart Mini-Prep DLC-2A Case Disassembly: step 1, image 2 of 2
      • Remove the back panel using a Phillips #1 Screwdriver on the four screws that hold it in place.
      Ask FixBot
    1. Cuisinart Mini-Prep DLC-2A Button Replacement, Button: step 2, image 1 of 1
      • Locate the Button Panel inside the blender.
      • Using your Phillips #1 Screwdriver, remove the two screws which hold the panel in place.
      Ask FixBot
    2. Cuisinart Mini-Prep DLC-2A Button Replacement: step 3, image 1 of 3 Cuisinart Mini-Prep DLC-2A Button Replacement: step 3, image 2 of 3 Cuisinart Mini-Prep DLC-2A Button Replacement: step 3, image 3 of 3
      • Locate the black box held in place on the panel.
      • Using your Spudger, wedge the black box out of its place to uncover the button
      Ask FixBot
    3. Cuisinart Mini-Prep DLC-2A Button Replacement: step 4, image 1 of 2 Cuisinart Mini-Prep DLC-2A Button Replacement: step 4, image 2 of 2
      • Once the black box is out of place, use your finger to push out the button.
      • Now replace the old button with your newly acquired button.
      Ask FixBot
Xavier Tapia
144 Reputation
1 Guide authored
1 Guide Comment
Hi,
Where’d you get the new buttons?
Mark B - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 89
All Time: 667
