Cuisinart DLC-8F Power Switch Assembly Replacement
  1. Cuisinart DLC-8F Power Switch Assembly Replacement, Power Switch Assembly: step 1, image 1 of 2 Cuisinart DLC-8F Power Switch Assembly Replacement, Power Switch Assembly: step 1, image 2 of 2
    • Remove the four 18 mm Phillips #2 screws from the bottom by prying up the rubber feet to access the screw hole.
  2. Cuisinart DLC-8F Power Switch Assembly Replacement: step 2, image 1 of 2 Cuisinart DLC-8F Power Switch Assembly Replacement: step 2, image 2 of 2
    • Gently lift the bottom cover from the main body.
  3. Cuisinart DLC-8F Power Switch Assembly Replacement: step 3, image 1 of 3 Cuisinart DLC-8F Power Switch Assembly Replacement: step 3, image 2 of 3 Cuisinart DLC-8F Power Switch Assembly Replacement: step 3, image 3 of 3
    • Pull out the three wires coming out of the power switch assembly by firmly grabbing the base of the wires and pulling.
  4. Cuisinart DLC-8F Power Switch Assembly Replacement: step 4, image 1 of 2 Cuisinart DLC-8F Power Switch Assembly Replacement: step 4, image 2 of 2
    • Remove the three 12 mm Phillips #2 screws from the power switch assembly.
  5. Cuisinart DLC-8F Power Switch Assembly Replacement: step 5, image 1 of 2 Cuisinart DLC-8F Power Switch Assembly Replacement: step 5, image 2 of 2
    • Pull out the power switch assembly with your hand.
    • This might take some jiggling and effort.
2 other people completed this guide.
David Colman
573 Reputation
4 Guides authored
Cal Poly, Team 8-6, Banghart Winter 2017 Member of Cal Poly, Team 8-6, Banghart Winter 2017
CPSU-BANGHART-W17S8G6
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 591
