Cuisinart DLC-8F Automatic Circuit Breaker Replacement
  1. Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Power Cable: step 1, image 1 of 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Power Cable: step 1, image 2 of 2
    • Remove the four 18 mm Phillips #2 screws from the bottom by prying up the rubber feet to access the screw hole.
  2. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: step 2, image 1 of 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: step 2, image 2 of 2
    • Gently lift the bottom cover from the main body.
  3. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: step 3, image 1 of 1
    • Remove the two 62 mm Phillips #2 screws from the cable retaining clip.
  4. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: step 4, image 1 of 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: step 4, image 2 of 2
    • Lift off the cable retaining
  5. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: step 5, image 1 of 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: step 5, image 2 of 2
    • Pull apart the two wires of the power cable at their connections as shown.
  6. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: step 6, image 1 of 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: step 6, image 2 of 2
    • Lift out the cable.
  7. Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Automatic Circuit Breaker: step 7, image 1 of 3 Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Automatic Circuit Breaker: step 7, image 2 of 3 Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Automatic Circuit Breaker: step 7, image 3 of 3
    • Pull out the power cable screw stand with your hand.
  8. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: step 8, image 1 of 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: step 8, image 2 of 2
    • Remove the two 15 mm Phillips #2 screws on the automatic circuit breaker.
  9. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: step 9, image 1 of 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: step 9, image 2 of 2
    • Pull out the automatic circuit breaker with your hand.
  10. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: step 10, image 1 of 3 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: step 10, image 2 of 3 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: step 10, image 3 of 3
    • Pull off the three wires by grabbing from the base of the wire.
David Colman
573 Reputation
4 Guides authored
Cal Poly, Team 8-6, Banghart Winter 2017 Member of Cal Poly, Team 8-6, Banghart Winter 2017
CPSU-BANGHART-W17S8G6
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 803
