Cuisinart DCC-1200 Coffee Carafe Handle Replacement
  1. Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: step 1, image 1 of 3 Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: step 1, image 2 of 3 Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: step 1, image 3 of 3
    • Wedge the metal spudger between the plug and the handle.
    • Carefully pry the plug with the metal spudger by applying pressure around the plug.
    • Too much pressure and prying can damage the plug.
  2. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: step 2, image 1 of 2 Cuisinart DCC-1200 Coffee Carafe Handle Replacement: step 2, image 2 of 2
    • Use the bit driver with the Phillips PH1 bit to remove the 27 millimeter long screw in the base of the handle.
  3. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: step 3, image 1 of 1
    • Lift up on and remove the lid from the carafe.
  4. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: step 4, image 1 of 2 Cuisinart DCC-1200 Coffee Carafe Handle Replacement: step 4, image 2 of 2
    • Position the metal spudger underneath the top cap of the handle.
    • Gently pry up to extract the upper assembly cap.
    • Pry carefully to prevent from causing aesthetic damage to upper assembly cap.
  5. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: step 5, image 1 of 1
    • Use the bit driver with the Phillips PH1 to remove the 5 millimeter screw in upper assembly of handle.
    • Remove handle by lifting straight up.
Austin Wheaton
861 Reputation
4 Guides authored
UW Stout, Team S8-G1, Ogden Spring 2018 Member of UW Stout, Team S8-G1, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G1
4 Members
5 Guides authored
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 36
All Time: 3,665
