Cuisinart DCC-1200 Hose Replacement
  1. Cuisinart DCC-1200  Hose Replacement, Water Hoses: step 1, image 1 of 3 Cuisinart DCC-1200  Hose Replacement, Water Hoses: step 1, image 2 of 3 Cuisinart DCC-1200  Hose Replacement, Water Hoses: step 1, image 3 of 3
    • Flip the coffee maker over so the bottom is facing upwards.
    • Use the screwdriver with size 4 extension with the T10 Torx bit to remove all four 17 mm long screws.
    • Lift the bottom cover off the bottom of the coffee maker.
  2. Cuisinart DCC-1200  Hose Replacement: step 2, image 1 of 2 Cuisinart DCC-1200  Hose Replacement: step 2, image 2 of 2
    • Gently squeeze the hose clamps together and begin moving the metal clamp away from the heating element.
  3. Cuisinart DCC-1200  Hose Replacement: step 3, image 1 of 3 Cuisinart DCC-1200  Hose Replacement: step 3, image 2 of 3 Cuisinart DCC-1200  Hose Replacement: step 3, image 3 of 3
    • Gently pull on the loose hose to remove it from the heating element.
  4. Cuisinart DCC-1200  Hose Replacement: step 4, image 1 of 3 Cuisinart DCC-1200  Hose Replacement: step 4, image 2 of 3 Cuisinart DCC-1200  Hose Replacement: step 4, image 3 of 3
    • Squeeze the clamp with tweezers on the opposite end of the hose from the one you already removed.
    • Once the clamp is free, gently pull upwards on the hose to remove it.
    • Replace the disconnected hose with a new functioning hose.
Austin Wheaton
861 Reputation
4 Guides authored
UW Stout, Team S8-G1, Ogden Spring 2018 Member of UW Stout, Team S8-G1, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G1
4 Members
5 Guides authored
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 157
All Time: 15,240
