Introduction
This guide will help you with replacing the power cord if your device is not receiving power. Please have a replacement power cord ready and unplug the machine before beginning work.
Remove the two 1.4mm Phillips #0 screws from the plastic protection plate.
Remove the plastic protection plate.
Remove the two 1.6mm Phillips #1 screws from the heating element.
Using a flathead screwdriver to remove the outer clips holding the heating unit in place.
Flip the heating element up to allow access to the circuit board.
Pull out the circuit board and rest it on the side of the machine.
Desolder the power cable from the motherboard.
