Cuisinart DCC-1100 Heating Element Replacement
  1. Cuisinart DCC-1100 Heating Element Replacement, Heating Element: step 1, image 1 of 3 Cuisinart DCC-1100 Heating Element Replacement, Heating Element: step 1, image 2 of 3 Cuisinart DCC-1100 Heating Element Replacement, Heating Element: step 1, image 3 of 3
    • Remove the coffee pot and unplug the maker.
    • Flip the coffee maker over so that way the bottom is facing you.
  2. Cuisinart DCC-1100 Heating Element Replacement: step 2, image 1 of 3 Cuisinart DCC-1100 Heating Element Replacement: step 2, image 2 of 3 Cuisinart DCC-1100 Heating Element Replacement: step 2, image 3 of 3
    • Remove the five 1.6mm Phillips #1 screws from the bottom.
    • Remove the bottom cover.
  3. Cuisinart DCC-1100 Heating Element Replacement: step 3, image 1 of 2 Cuisinart DCC-1100 Heating Element Replacement: step 3, image 2 of 2
    • Remove the two 1.6mm Phillips #0 screws from the heating element.
    • Lift up the heating element and remove the hot plate.
  4. Cuisinart DCC-1100 Heating Element Replacement: step 4, image 1 of 2 Cuisinart DCC-1100 Heating Element Replacement: step 4, image 2 of 2
    • Disconnect the heating element.
    • Pinch the tube clips and remove from tubes from the heating element.
Tanvirul Arafin
143 Reputation
1 Guide authored
USF Tampa, Team S20-G4, Passmore Spring 2018 Member of USF Tampa, Team S20-G4, Passmore Spring 2018
USFT-PASSMORE-S18S20G4
4 Members
7 Guides authored
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 22
All Time: 3,205
