Cuisinart DCC-1100 Display Replacement
  1. Cuisinart DCC-1100 Display Replacement, Display: step 1, image 1 of 2 Cuisinart DCC-1100 Display Replacement, Display: step 1, image 2 of 2
    • Unplug the coffee maker and remove the pot.
  2. Cuisinart DCC-1100 Display Replacement: step 2, image 1 of 2 Cuisinart DCC-1100 Display Replacement: step 2, image 2 of 2
    • Open the lid of the coffee pot.
    • Remove the two 1.6mm Phillips #1 screws from inside of the lid.
  3. Cuisinart DCC-1100 Display Replacement: step 3, image 1 of 1
    • Remove the lid.
  4. Cuisinart DCC-1100 Display Replacement: step 4, image 1 of 1
    • Remove the two 1.3mm Phillips #0 screws from the display.
  5. Cuisinart DCC-1100 Display Replacement: step 5, image 1 of 2 Cuisinart DCC-1100 Display Replacement: step 5, image 2 of 2
    • Slide the display into the coffee maker so that way you can access the screws in the back.
    • Remove the four 1mm Phillips #0 screws from the back of the display.
  6. Cuisinart DCC-1100 Display Replacement: step 6, image 1 of 2 Cuisinart DCC-1100 Display Replacement: step 6, image 2 of 2
    • Remove the back panel from the display.
    • Remove the 1mm Phillips #0 screw from the motherboard.
  7. Cuisinart DCC-1100 Display Replacement: step 7, image 1 of 1
    • Desolder the display from the motherboard.
2 other people completed this guide.
Josh Harvey
886 Reputation
4 Guides authored
USF Tampa, Team S20-G4, Passmore Spring 2018 Member of USF Tampa, Team S20-G4, Passmore Spring 2018
USFT-PASSMORE-S18S20G4
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 963
