Introduction
If your Cub Cadet LT1042 Riding Mower won't start because of a bad starter, this guide will help you replace it with a new one. The starter motor connects to the battery and engages the engine when you turn the key.
Before you begin, inspect the lawn mower battery to check the voltage and ensure the connections are secure. If you find any corrosion on the battery terminals, clean it with a wire brush. Use a multimeter to test other components, like the starter solenoid and magneto, to confirm that the starter motor is the only part not working.
Follow the steps in order, and make sure to disconnect the battery before you begin to ensure a safe repair. If you have recently used your mower, make sure the engine is cool to avoid burns.
Remove the plastic covers from the battery terminals.
Use a wrench to disconnect the lawn mower battery terminals.
