CrystalView NB4-35788 Battery Replacement
  1. CrystalView NB4-35788 Battery Replacement, Battery: step 1, image 1 of 1
    • Power off the device before beginning disassembly.
    • Using a Phillips #00 Screwdriver, take out the following screws:
    • Two 6 mm screws
    • Three 4 mm screws
    • Four 3 mm screws
    • These screws can be taken out in any order.
  2. CrystalView NB4-35788 Battery Replacement: step 2, image 1 of 1
    • Using a Phillips #00 Screwdriver, remove the screws located under the top two standoffs.
  3. CrystalView NB4-35788 Battery Replacement: step 3, image 1 of 1
    • Remove the cover off the back of the device.
  4. CrystalView NB4-35788 Battery Replacement: step 4, image 1 of 1
    • Remove the battery using a plastic spudger.
    • Do not use a metal spudger, as this can damage the device.
  5. CrystalView NB4-35788 Battery Replacement: step 5, image 1 of 2 CrystalView NB4-35788 Battery Replacement: step 5, image 2 of 2
    • Peel back the yellow film on the old battery to expose the red and black wires
    • De-solder these wires to disconnect the old battery
    • Be careful while using a soldering iron as it is extremely hot.
    • Follow the How To Solder and Desolder Connections guide for help.
Courtney Clark
218 Reputation
2 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 300
