Introduction
Follow this guide to replace the blade in your Cricut Maker 3.
If your Cricut is tearing the material instead of cutting it, or if the material is not being cut completely, you may need to replace the blade.
Open the Cricut by lifting the top silver lid. The front tray will also open.
Partially open clamp B on the tool holder by pulling the plastic latch away from the tool holder.
Grab the blade housing by the top and remove it from the tool holder.
Hold the blade housing between your index finger and middle finger with the blade pointed away from your palm.
Use your thumb to press the plunger to push the blade out of the housing.
