Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
Remove the copper plate covering the motherboard by desoldering the ten solder points so that the copper plate is free.
The last point is hidden by the soldering iron.
Remove the copper plate once all the solder points are undone.
Remove adhesive tape covering the three wires connected to the motherboard.
Desolder the solder points connecting the wires to the mother board.
