Creative Nomad Jukebox Zen Auxiliary Jack Input placement
  1. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: step 1, image 1 of 3 Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: step 1, image 2 of 3 Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: step 1, image 3 of 3
    • Use a J0 screwdriver to remove the eight 3.5mm screws.
  2. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: step 2, image 1 of 3 Creative Nomad Jukebox Zen Auxiliary Jack Input placement: step 2, image 2 of 3 Creative Nomad Jukebox Zen Auxiliary Jack Input placement: step 2, image 3 of 3
    • Use the plastic opening tool to open the top cover by carefully prying at each corner.
  3. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Screen Cover: step 3, image 1 of 1
    • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover and remove it.
  4. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Auxiliary Port: step 4, image 1 of 1
    • Using a soldering iron, melt the solder in order to free the auxiliary jack.
    • How To Solder and Desolder Connections Use soldering gun with care as it becomes extremely hot and can cause burns
  5. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: step 5, image 1 of 1
    • Using the plastic opening tool, gently pry up the other side of the auxiliary jack motherboard.
  6. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: step 6, image 1 of 1
    • Using the plastic pulling tool, pull the plastic housing of the device out of the way in order to wiggle the the auxiliary jack motherboard free.
Bradley McHugh
101 Reputation
1 Guide authored
IUPUI, Team S4-G5, Baechle Spring 2017 Member of IUPUI, Team S4-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G5
4 Members
5 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 565
