Up to 20% off select tools
Crankcase Opening Procedure
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
20
All Time:
147
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
pre-req guide on opening the crankcase cover in preparation for service inside the crankcase chamber
    1. Crankcase Opening Procedure, Disconnect the spark plug: step 1, image 1 of 2 Crankcase Opening Procedure, Disconnect the spark plug: step 1, image 2 of 2
      • Before you begin, disconnect the spark plug connector from the spark plug.
      Ask FixBot
    1. Crankcase Opening Procedure, Elevate the generator: step 2, image 1 of 1
      • Elevate the generator on a set of stable risers, like wooden blocks.
      • Place a drain pan underneath the generator, between the blocks.
      Ask FixBot
    2. Crankcase Opening Procedure, Drain the oil: step 3, image 1 of 3 Crankcase Opening Procedure, Drain the oil: step 3, image 2 of 3 Crankcase Opening Procedure, Drain the oil: step 3, image 3 of 3
      • Use a 12 mm socket to remove the oil drain plugs from either side of the generator.
      • Give the oil a few minutes to drain from the cylinder and crankcase housing.
      • Tip the generator back and forth towards either drain hole to allow any last bits of oil to drain.
      • Once the oil is finished draining, replace the drain plugs.
      • Tighten the drain plugs to 13 ft-lb (18 N-m) of torque.
      • During reassembly, be sure to refill the engine oil:
      • Use up to 0.58 liters of SAE 10W-30 oil, until the dipstick is almost completely submerged.
      Ask FixBot
    1. Crankcase Opening Procedure, Remove the shaft guard: step 4, image 1 of 3 Crankcase Opening Procedure, Remove the shaft guard: step 4, image 2 of 3 Crankcase Opening Procedure, Remove the shaft guard: step 4, image 3 of 3
      • Use a 12 mm socket to remove the two 20 mm-long bolts securing the shaft guard to the crankcase cover.
      • Remove the shaft guard.
      Ask FixBot
    2. Crankcase Opening Procedure, Unfasten the crankcase cover: step 5, image 1 of 1
      • Use a 12 mm socket to remove the six 32 mm-long bolts securing the crankcase cover.
      • During reassembly, tighten these bolts down to 17 ft-lb (24 N-m) of torque.
      Ask FixBot
    3. Crankcase Opening Procedure, Unfasten the upper cylinder shroud: step 6, image 1 of 3 Crankcase Opening Procedure, Unfasten the upper cylinder shroud: step 6, image 2 of 3 Crankcase Opening Procedure, Unfasten the upper cylinder shroud: step 6, image 3 of 3
      • Use a 12 mm socket to remove the nut securing the upper cylinder shroud and air guide plate.
      • Use a 10 mm socket to remove the 12 mm-long bolt securing the air guide plate.
      • Remove the air guide plate.
      Ask FixBot
    4. Crankcase Opening Procedure: step 7, image 1 of 3 Crankcase Opening Procedure: step 7, image 2 of 3 Crankcase Opening Procedure: step 7, image 3 of 3
      • Use a 10 mm socket to remove the 12 mm-long bolt securing the upper cylinder shroud.
      • Tilt the upper shroud upward slightly so the hook on the right of the shroud is free from the bolt.
      • You may need to bend the hook out of shape slightly to reposition the shroud like this.
      • If you do bend the hook, simply use a pair of pliers to bend it back into place before refastening the nut during reassembly.
      Ask FixBot
    5. Crankcase Opening Procedure, Remove the crankcase cover: step 8, image 1 of 3 Crankcase Opening Procedure, Remove the crankcase cover: step 8, image 2 of 3 Crankcase Opening Procedure, Remove the crankcase cover: step 8, image 3 of 3
      • When the shroud is sufficiently out of the way, remove the crankcase cover.
      • Residual oil may leak when you remove the cover. Be ready to catch any spillage.
      Ask FixBot
Author
with
Tarun Thiruma
41,054 Reputation
133 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 147
