Cosori Pro II Heating Coil Replacement
    1. Cosori Pro II Heating Coil Replacement, Shell: step 1, image 1 of 1
      • Flip the device upside down and remove all of the Phillips #1 screws.
      Ask FixBot
    2. Cosori Pro II Heating Coil Replacement: step 2, image 1 of 2 Cosori Pro II Heating Coil Replacement: step 2, image 2 of 2
      • Use an opening tool to push on the retaining hooks to disengage them while prying slightly.
      • Remove the panel.
      Ask FixBot
    3. Cosori Pro II Heating Coil Replacement: step 3, image 1 of 1
      • Use a Phillips #1 screwdriver to remove all four screws.
      • Lift off the bracket.
      • When lifting this off be careful to not unplug the screen.
      Ask FixBot
    4. Cosori Pro II Heating Coil Replacement: step 4, image 1 of 2 Cosori Pro II Heating Coil Replacement: step 4, image 2 of 2
      • Use a Phillips #0 screwdriver to remove all the screws connecting to the shell.
      • Dissemble the shell going up to separate the basket holder.
      Ask FixBot
    5. Cosori Pro II Heating Coil Replacement: step 5, image 1 of 2 Cosori Pro II Heating Coil Replacement: step 5, image 2 of 2
      • Use a Phillips #0 screwdriver and the 150 mm Flex Extension to unscrew the bottom plastic connecting to the basket holder.
      • Be careful to not apply too much force to the metal as it can cause it to warp it, and so it is easy rescrew the plastic piece in place.
      Ask FixBot
    6. Cosori Pro II Heating Coil Replacement: step 6, image 1 of 2 Cosori Pro II Heating Coil Replacement: step 6, image 2 of 2
      • Pull the bottom shell down pulling at the sides to get them over screw holes.
      Ask FixBot
    1. Cosori Pro II Heating Coil Replacement, Heating Coil: step 7, image 1 of 1
      • Remove the screws holding the cables into the distribution board with a Phillips #2 screwdriver.
      • Remove the 2 cables that connect the heating coil to the distribution board on the top of the cooking chamber, there should be one blue and one white cable, both with a white shroud leading into the cooking chamber.
      Ask FixBot
    2. Cosori Pro II Heating Coil Replacement: step 8, image 1 of 2 Cosori Pro II Heating Coil Replacement: step 8, image 2 of 2
      • Flip the device backward so the metal walls appear in a U-shape.
      • Remove the 3 screws inside the cooking chamber that hold the heating coil in place using a 2 Philips screwdriver.
      • Remove the heating coil.
      Ask FixBot
2 other people completed this guide.
2 Guide Comments
Le ventilateur démarre pas , c’est quoi le problème ?
amine _agm - Reply Share
Does anyone know what´s reference of ic1 is on the distribution board? IC1 Image
Helio Goncalves - Reply Share
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 136
All Time: 1,386
