Corsair Void Pro RGB Lights Replacement
  1. Corsair Void Pro RGB Lights Replacement, Earcup: step 1, image 1 of 1
    • Carefully remove earmuff from headphones by getting a grip under the earmuff cushion and peeling up over the lip that keeps it in place.
  2. Corsair Void Pro RGB Lights Replacement: step 2, image 1 of 2 Corsair Void Pro RGB Lights Replacement: step 2, image 2 of 2
    • Using the Phillips #0 screwdriver, unscrew the seven 6.4 mm screws holding the black speaker cover in place.
    • If you are disassembling the lefthand earfmuff, there will be eight 6.4 mm screws to remove.
  3. Corsair Void Pro RGB Lights Replacement: step 3, image 1 of 2 Corsair Void Pro RGB Lights Replacement: step 3, image 2 of 2
    • Remove and set aside the black panel, taking care to keep the wires attached.
    • The panel should lift up without much force. If the panel does not budge, carefully use the iFixit plastic opening tool to dislodge the piece.
  4. Corsair Void Pro RGB Lights Replacement, Battery: step 4, image 1 of 2 Corsair Void Pro RGB Lights Replacement, Battery: step 4, image 2 of 2
    • Using the Phillips #0 screwdriver, remove the three 6.4 mm screws on the black plastic panel with the grid of holes.
  5. Corsair Void Pro RGB Lights Replacement: step 5, image 1 of 2 Corsair Void Pro RGB Lights Replacement: step 5, image 2 of 2
    • Carefully unplug the wire that connects the battery pack to the headphones.
    • This should not take too much force.
  6. Corsair Void Pro RGB Lights Replacement: step 6, image 1 of 1
    • Remove the clear plastic covering and set aside.
  7. Corsair Void Pro RGB Lights Replacement, Lights: step 7, image 1 of 2 Corsair Void Pro RGB Lights Replacement, Lights: step 7, image 2 of 2
    • There is a small circuit board near the bottom of the muff.
    • Using a Phillips #0 screwdriver, unscrew the single screw holding the circuit board in place.
  8. Corsair Void Pro RGB Lights Replacement: step 8, image 1 of 1
    • Remove the circuit board from its plastic slot.
    • If this is the first time the lights have been removed from the headphones, you may need to wiggle the circuit board out of place or use plastic tweezers to loosen it from the manufacturer's adhesive.
  9. Corsair Void Pro RGB Lights Replacement: step 9, image 1 of 1
    • Desolder the three points where the wires connect to the circuit board. For detailed instructions on soldering, see this helpful guide.
    • Take note of where each of the wires goes to simplify the resoldering process.
    • Follow these steps again to replace the light on the other earcup.
Gianna Nobili
827 Reputation
5 Guides authored
Cal Poly, Team S9-G13, Maness Spring 2019 Member of Cal Poly, Team S9-G13, Maness Spring 2019
CPSU-MANESS-S19S9G13
4 Members
14 Guides authored
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 15
All Time: 1,307
