Corsair Void Pro RGB Battery Replacement
  1. Corsair Void Pro RGB Battery Replacement, Earcup: step 1, image 1 of 1
    • Carefully remove earmuff from headphones by getting a grip under the earmuff cushion and peeling up over the lip that keeps it in place.
  2. Corsair Void Pro RGB Battery Replacement: step 2, image 1 of 2 Corsair Void Pro RGB Battery Replacement: step 2, image 2 of 2
    • Using the Phillips #0 screwdriver, unscrew the seven 6.4 mm screws holding the black speaker cover in place.
    • If you are disassembling the lefthand earfmuff, there will be eight 6.4 mm screws to remove.
  3. Corsair Void Pro RGB Battery Replacement: step 3, image 1 of 2 Corsair Void Pro RGB Battery Replacement: step 3, image 2 of 2
    • Remove and set aside the black panel, taking care to keep the wires attached.
    • The panel should lift up without much force. If the panel does not budge, carefully use the iFixit plastic opening tool to dislodge the piece.
  4. Corsair Void Pro RGB Battery Replacement, Battery: step 4, image 1 of 2 Corsair Void Pro RGB Battery Replacement, Battery: step 4, image 2 of 2
    • Using the Phillips #0 screwdriver, remove the three 6.4 mm screws on the black plastic panel with the grid of holes.
  5. Corsair Void Pro RGB Battery Replacement: step 5, image 1 of 2 Corsair Void Pro RGB Battery Replacement: step 5, image 2 of 2
    • Carefully unplug the wire that connects the battery pack to the headphones.
    • This should not take too much force.
  6. Corsair Void Pro RGB Battery Replacement: step 6, image 1 of 1
    • Remove the clear plastic covering and set aside.
Gianna Nobili
827 Reputation
5 Guides authored
Cal Poly, Team S9-G13, Maness Spring 2019 Member of Cal Poly, Team S9-G13, Maness Spring 2019
CPSU-MANESS-S19S9G13
4 Members
14 Guides authored
Past 24 Hours: 14
Past 7 Days: 60
Past 30 Days: 231
All Time: 18,489
