Core Assembly Removal
  1. Core Assembly Removal, Unfasten the back cover screws: step 1, image 1 of 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
    • Don’t worry about removing the screws, they will stay in place in the back cover.
  2. Core Assembly Removal, Wedge open the back cover: step 2, image 1 of 2 Core Assembly Removal, Wedge open the back cover: step 2, image 2 of 2
    • Insert an opening tool between the back cover and the metal housing.
    • Twist the opening tool to create a wider gap.
    • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
  3. Core Assembly Removal, Disconnect the sensor flex cable: step 3, image 1 of 3 Core Assembly Removal, Disconnect the sensor flex cable: step 3, image 2 of 3 Core Assembly Removal, Disconnect the sensor flex cable: step 3, image 3 of 3
    • Lay the watch face down.
    • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  4. Core Assembly Removal, Remove the back cover: step 4, image 1 of 2 Core Assembly Removal, Remove the back cover: step 4, image 2 of 2
    • Remove the back cover.
    • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
  5. Core Assembly Removal, Unplug the display connector: step 5, image 1 of 2 Core Assembly Removal, Unplug the display connector: step 5, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the display flex cable from the motherboard.
  6. Core Assembly Removal, Loosen the core assembly: step 6, image 1 of 2 Core Assembly Removal, Loosen the core assembly: step 6, image 2 of 2
    • The core's plastic frame fits tightly within the watch's metal housing.
    • Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
    • Twist and tilt the spudger to lever the core assembly out of the metal housing.
  7. Core Assembly Removal, Remove the core assembly: step 7, image 1 of 3 Core Assembly Removal, Remove the core assembly: step 7, image 2 of 3 Core Assembly Removal, Remove the core assembly: step 7, image 3 of 3
    • Carefully thread the display flex cable through the gap on the core's plastic frame.
    • Remove the core assembly.
Tobias Isakeit
117,756 Reputation
188 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,541 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 17
All Time: 956
