Coolpad Defiant Screen Replacement
  1. Coolpad Defiant Screen Replacement, Back Cover: step 1, image 1 of 2 Coolpad Defiant Screen Replacement, Back Cover: step 1, image 2 of 2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Screen Replacement: step 2, image 1 of 1
    • Remove the back cover from your device.
  3. Coolpad Defiant Screen Replacement, Battery: step 3, image 1 of 1
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
  4. Coolpad Defiant Screen Replacement, Rear Camera: step 4, image 1 of 1
    • Using a Phillips #000 screwdriver, remove the screws holding the rear mid-frame cover to the mid-frame assembly.
  5. Coolpad Defiant Screen Replacement: step 5, image 1 of 2 Coolpad Defiant Screen Replacement: step 5, image 2 of 2
    • Using either a plastic pry tool or your hands, pry the plastic cover away.
  6. Coolpad Defiant Screen Replacement: step 6, image 1 of 1
    • Using the Phillips #000 screwdriver, remove the three screws holding the top logic board to the main frame.
  7. Coolpad Defiant Screen Replacement: step 7, image 1 of 3 Coolpad Defiant Screen Replacement: step 7, image 2 of 3 Coolpad Defiant Screen Replacement: step 7, image 3 of 3
    • Using the plastic pry tool, remove the flex cables for the screen, side buttons, and digitizer.
    • Using the same tool, remove the antenna from the bottom logic board
  8. Coolpad Defiant Screen Replacement: step 8, image 1 of 3 Coolpad Defiant Screen Replacement: step 8, image 2 of 3 Coolpad Defiant Screen Replacement: step 8, image 3 of 3
    • Carefully pull up on the upper logic board starting from the top and pull it straight up.
    • Once the logic board is lifted perpendicular to the mid-frame, remove the flex cable on the bottom left side of the board.
  9. Coolpad Defiant Screen Replacement: step 9, image 1 of 1
    • Flipping the logic board upside down, use the plastic pry tool to disconnect the flex cable connecting the camera to the logic board.
    • Pull straight up on the camera and it will slide out of the logic board.
  10. Coolpad Defiant Screen Replacement, Screen: step 10, image 1 of 2 Coolpad Defiant Screen Replacement, Screen: step 10, image 2 of 2
    • Using the plastic pry tool, remove the lower logic board, starting with the removal of the vibrator and working across the board.
    • The board is held down by adhesives, so force is required to remove it.
    • Since the board is fragile, be careful when removing the board.
  11. Coolpad Defiant Screen Replacement: step 11, image 1 of 1
    • Place the suction cup tool on the bottom left corner of the screen.
  12. Coolpad Defiant Screen Replacement: step 12, image 1 of 1
    • Pull straight up on the suction cup to pop the screen off.
    • Some heat may need to be applied to loosen the adhesive. Use a hair dryer or heat gun. This device was easy pulled apart without heat tho.
    • Be sure to lift the bottom of the screen up. Be careful of the cables on the top of the screen.
  13. Coolpad Defiant Screen Replacement: step 13, image 1 of 1
    • Once the screen is free from the adhesive, slide the flex cable through the middle chassis assembly.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 3,185
