Shop the Holiday Gift Guide
Coolpad Defiant Rear Camera Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
44
All Time:
850
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Is your phone not taking photos properly? Consider using this guide to replace the rear camera in your device.
Tools
    1. Coolpad Defiant Rear Camera Replacement, Back Cover: step 1, image 1 of 2 Coolpad Defiant Rear Camera Replacement, Back Cover: step 1, image 2 of 2
      • Turn the phone with the back cover facing towards you.
      • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
      • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
      Ask FixBot
    2. Coolpad Defiant Rear Camera Replacement: step 2, image 1 of 1
      • Remove the back cover from your device.
      Ask FixBot
    1. Coolpad Defiant Rear Camera Replacement, Battery: step 3, image 1 of 1
      • Find the gap on the bottom of the battery.
      • With a tool or with your hands, pull the battery upward and set it aside safely.
      • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
      • Be careful with old or damaged batteries and dispose of it appropriately
      Ask FixBot
    1. Coolpad Defiant Rear Camera Replacement, Rear Camera: step 4, image 1 of 1
      • Using a Phillips #000 screwdriver, remove the screws holding the rear mid-frame cover to the mid-frame assembly.
      Ask FixBot
    2. Coolpad Defiant Rear Camera Replacement: step 5, image 1 of 2 Coolpad Defiant Rear Camera Replacement: step 5, image 2 of 2
      • Using either a plastic pry tool or your hands, pry the plastic cover away.
      Ask FixBot
    3. Coolpad Defiant Rear Camera Replacement: step 6, image 1 of 1
      • Using the Phillips #000 screwdriver, remove the three screws holding the top logic board to the main frame.
      Ask FixBot
    4. Coolpad Defiant Rear Camera Replacement: step 7, image 1 of 3 Coolpad Defiant Rear Camera Replacement: step 7, image 2 of 3 Coolpad Defiant Rear Camera Replacement: step 7, image 3 of 3
      • Using the plastic pry tool, remove the flex cables for the screen, side buttons, and digitizer.
      • Using the same tool, remove the antenna from the bottom logic board
      Ask FixBot
    5. Coolpad Defiant Rear Camera Replacement: step 8, image 1 of 3 Coolpad Defiant Rear Camera Replacement: step 8, image 2 of 3 Coolpad Defiant Rear Camera Replacement: step 8, image 3 of 3
      • Carefully pull up on the upper logic board starting from the top and pull it straight up.
      • Once the logic board is lifted perpendicular to the mid-frame, remove the flex cable on the bottom left side of the board.
      Ask FixBot
    6. Coolpad Defiant Rear Camera Replacement: step 9, image 1 of 1
      • Flipping the logic board upside down, use the plastic pry tool to disconnect the flex cable connecting the camera to the logic board.
      • Pull straight up on the camera and it will slide out of the logic board.
      Ask FixBot
Author
with
Johnny Boland
535 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 44
All Time: 850
