Up to 20% off select tools
Control Box Opening Procedure
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
19
All Time:
128
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
Introduction
Go to step 1 ↓
Pre-req guide on opening the control box housing in preparation for service.
    1. Control Box Opening Procedure, Disconnect the spark plug: step 1, image 1 of 2 Control Box Opening Procedure, Disconnect the spark plug: step 1, image 2 of 2
      • Before you begin, disconnect the spark plug connector from the spark plug.
      Ask FixBot
    1. Control Box Opening Procedure, Remove the control box cover panel: step 2, image 1 of 1
      • Use a Phillips #2 screwdriver to remove the five 15 mm screws securing the control box cover.
      Ask FixBot
    2. Control Box Opening Procedure: step 3, image 1 of 3 Control Box Opening Procedure: step 3, image 2 of 3 Control Box Opening Procedure: step 3, image 3 of 3
      • Use a flathead screwdriver to pry and loosen the control panel from the control box.
      • Tilt the control panel down so the rear of the panel is accessible.
      Ask FixBot
Author
with
Tarun Thiruma
41,054 Reputation
133 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 128
