Autosampler Configuration (For Old & New Versions)
    1. Autosampler Configuration  (For Old & New Versions), Starting the configuration process.: step 1, image 1 of 2 Autosampler Configuration  (For Old & New Versions), Starting the configuration process.: step 1, image 2 of 2
      • 1. Turn on the autosampler. Screen will read "...STANDBY..."
      • 2. Press "ENTER/PROGRAM" button. Use arrows to highlight "CONFIGURE". Press "ENTER/PROGRAM" button
      • This will allow you to use the arrows to shuffle through the different configuration options. To select the one you want, press the "ENTER/PROGRAM" button.
      Ask FixBot
    2. Autosampler Configuration  (For Old & New Versions), Configuring "set clock".: step 2, image 1 of 1
      • The first option for configuring is "SET CLOCK"
      • 3. Press "ENTER/PROGRAM" to "SET CLOCK". Use the numeric keys to set the time and date. You can use the arrows to move. When finished. Press "ENTER/PROGRAM" button.
      Ask FixBot
    3. Autosampler Configuration  (For Old & New Versions), Configuring "bottles and sizes".: step 3, image 1 of 1
      • 4. Press "ENTER/PROGRAM" to configure "BOTTLES AND SIZES".
      • Use arrows to select "PORTABLE" sampler. Press "ENTER/PROGRAM" to configure bottles and sizes.
      • Use arrows to select "24" botles. Press "ENTER/PROGRAM" button.
      • Use numeric keys to enter "1000" mL for the "BOTTLE VOLUME". Press "ENTER/PROGRAM" button.
      Ask FixBot
    4. Autosampler Configuration  (For Old & New Versions), Configuring "suction line".: step 4, image 1 of 1
      • 5. Press "ENTER/PROGRAM" to configure "SUCTION LINE".
      • Use arrow to select "3/8" inch for "SUCTION LINE I.D." Press "ENTER/PROGRAM" button.
      • Use arrow to select "VINYL" for "SUCTION LINE" type. Press "ENTER/PROGRAM" button.
      • Use numeric keys to enter "25" feet for "SUCTION LINE LENGTH". Press "ENTER/PROGRAM" button.
      • The suction line length may change based on location and should be measured!
      Ask FixBot
    5. Autosampler Configuration  (For Old & New Versions), Configuring "liquid detector".: step 5, image 1 of 1
      • 6. Press "ENTER/PROGRAM" button to configure "LIQUID DETECTOR".
      • Use arrows to select "ENABLE" "LIQUID DECTOR". Press "ENTER/PROGRAM" button.
      • Use numeric keys to enter "3" "RINSE CYCLES." Press "ENTER/PROGRAM" button.
      • Screen will read "ENTER HEAD MANUALLY?" Use arrows to select "NO". Press "ENTER/PROGRAM" button.
      • Screen will read "RETRY UP TO X TIMES WHEN SAMPLING?" Use numeric keys to enter "3". Press "ENTER/PROGRAM" button.
      Ask FixBot
    6. Autosampler Configuration  (For Old & New Versions), Configuring "programming mode".: step 6, image 1 of 1
      • 7. Press "ENTER/PROGRAM" to configure "PROGRAMMING MODE".
      • Use arrows to select "BASIC" mode. Press "ENTER/PROGRAM" button.
      Ask FixBot
    7. Autosampler Configuration  (For Old & New Versions), Configuring "calibrate sampler".: step 7, image 1 of 1
      • 8. Press "ENTER/PROGRAM" to configure "CALIBRATE SAMPLER".
      • Use arrows to select "DISABLE" "CALIBRATE SAMPLER". Press "ENTER/PROGRAM" button.
      Ask FixBot
    8. Autosampler Configuration  (For Old & New Versions), Configuring "start time delay".: step 8, image 1 of 1
      • 9. Press "ENTER/PROGRAM" to configure "START TIME DELAY". Press "ENTER/PROGRAM" button.
      • Screen will read "X MINUTE DELAY TO START." Use numeric keys to enter "0" minutes. Press "ENTER/PROGRAM" button.
      Ask FixBot
    9. Autosampler Configuration  (For Old & New Versions), Configuring "enabling pin".: step 9, image 1 of 1
      • 10. Press "ENTER/PROGRAM" to configure "ENABLE PIN". Press "ENTER/PROGRAM" button.
      • Use arrow to select "NO" for "MASTER/SLAVE MODE?" Press "ENTER/PROGRAM" button.
      • Use arrow to select "NO" for "SAMPLE UPON DISABLE?" Press "ENTER/PROGRAM" button.
      • Use arrow to select "NO" for "SAMPLE UPON ENABLE?" Press "ENTER/PROGRAM" button.
      • Use arrow to select "NO" for "RESET SAMPLE INTERVAL?" Press "ENTER/PROGRAM" button.
      • Use arrow to select "NO" for "INHIBIT COUNTDOWN?" Press "ENTER/PROGRAM" button.
      Ask FixBot
    10. Autosampler Configuration  (For Old & New Versions), Configuring "event mark".: step 10, image 1 of 1
      • 11. Press "ENTER/PROGRAM" to configure "EVENT MARK". Press "ENTER/PROGRAM" button.
      • Use arrow to select "CONTINUOUS SIGNAL". Press "ENTER/PROGRAM" button.
      • Use arrow to select "PUMP CYCLE". Press "ENTER/PROGRAM" button.
      • It is critical this setting is configured in order for the sensor node to operate the autosampler!
      Ask FixBot
    11. Autosampler Configuration  (For Old & New Versions), Configuring "purge counts".: step 11, image 1 of 1
      • 12. Press "ENTER/PROGRAM" to configure "PURGE COUNTS". Press "ENTER/PROGRAM" button.
      • Use numeric keys to enter "XX" for "PRE-SAMPLE COUNTS". Press "ENTER/PROGRAM" button.
      • Use numeric keys to enter "XX" for "POST-SAMPLE COUNTS". Press "ENTER/PROGRAM" button.
      Ask FixBot
    12. Autosampler Configuration  (For Old & New Versions), Configuring "tubing life".: step 12, image 1 of 1
      • 12. Press "ENTER/PROGRAM" to configure "TUBING LIFE". Press "ENTER/PROGRAM" button.
      • Screen will read "X PUMP COUNTS, WARNING AT XXX000". Press "ENTER/PROGRAM" button.
      • Use arrows to select "NO" for "RESET PUMP COUNTER?". Press "ENTER/PROGRAM" button.
      • Use numeric keys to enter "XXX000" for "PUMP COUNTS TO WARNING". Press "ENTER/PROGRAM" button.
      Ask FixBot
    13. Autosampler Configuration  (For Old & New Versions), Configuring "program lock".: step 13, image 1 of 1
      • 13. Press "ENTER/PROGRAM" to configure "PROGRAM LOCK". Press "ENTER/PROGRAM" button.
      • Use arrows to select "DISABLE" "PROGRAM LOCK". Press "ENTER/PROGRAM" button.
      Ask FixBot
    14. Autosampler Configuration  (For Old & New Versions), Configuring "sampler ID".: step 14, image 1 of 1
      • 15. The next configuration option is "SAMPLER ID". Skip this configuration step by using the arrows.
      Ask FixBot
    15. Autosampler Configuration  (For Old & New Versions), Configuring "run diagonostics".: step 15, image 1 of 1
      • 16. The next configuration option is "RUN DIAGNOSTICS". Skip this configuration step by using the arrows.
      Ask FixBot
Finish Line
2 other people completed this guide.
Brooke Mason
2,958 Reputation
17 Guides authored
Open-Storm Member of Open-Storm
Community
15 Members
275 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 64
All Time: 625
