Shop the Holiday Gift Guide
Introduction
Go to step 1 ↓
The Nokia 2605 Mirage is a flip phone released in 2008. Due to this device's age and simplistic model, users will find it is easy to repair, maintain, or replace components within the phone. This guide provides steps in order to tear down the device and give access to its motherboard, battery, and other internal components.
No special skills are required for this breakdown.
Note: These phones are an older model and the plastic components making up the device, including the outer case, may have become brittle. When using a spudger, assess the plastic components and watch for cracks when applying pressure.
Tools
This teardown is not a repair guide. To repair your Nokia 2605, use our service manual.
    1. Nokia 2605 Teardown, Nokia 2605 Teardown: step 1, image 1 of 1
      • The indicated 3 screws must be removed in order to get to the motherboard.
      Ask FixBot
    2. Nokia 2605 Teardown: step 2, image 1 of 1
      • Remove all 3 screws using a T5 Torx Screwdriver.
      Ask FixBot
    3. Nokia 2605 Teardown: step 3, image 1 of 1
      • Slide a spudger tool between the phone's exterior case and its internal battery case, starting at the bottom corners. Pry the two components apart using the spudger and move the tool towards the top of the device.
      • As you move toward the top, remove the camera and volume buttons.
      Ask FixBot
    4. Nokia 2605 Teardown: step 4, image 1 of 2 Nokia 2605 Teardown: step 4, image 2 of 2
      • Remove the internal battery case. This will give you access to the motherboard and other internal components.
      • Do NOT detach the motherboard from the backpiece (attached at the upper left corner by a black strip)
      Ask FixBot
Dorsa
143 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 42
All Time: 1,757
