Compaq Presario CQ60 Keyboard Replacement
  1. Compaq Presario CQ60 Keyboard Replacement, Slide battery latch: step 1, image 1 of 2 Compaq Presario CQ60 Keyboard Replacement, Slide battery latch: step 1, image 2 of 2
    • Slide battery latch to left
    • Simultaneously lift battery
  2. Compaq Presario CQ60 Keyboard Replacement: step 2, image 1 of 3 Compaq Presario CQ60 Keyboard Replacement: step 2, image 2 of 3 Compaq Presario CQ60 Keyboard Replacement: step 2, image 3 of 3
    • Lift and remove battery
  3. Compaq Presario CQ60 Keyboard Replacement, Unscrew keyboard: step 3, image 1 of 2 Compaq Presario CQ60 Keyboard Replacement, Unscrew keyboard: step 3, image 2 of 2
    • Remove 3x M2.5x4mm
  4. Compaq Presario CQ60 Keyboard Replacement, Lift keyboard: step 4, image 1 of 3 Compaq Presario CQ60 Keyboard Replacement, Lift keyboard: step 4, image 2 of 3 Compaq Presario CQ60 Keyboard Replacement, Lift keyboard: step 4, image 3 of 3
    • Lift the keyboard in the middle with a spudger
    • Remove 4 clips by bending keyboard in middle, do not force the clips at the sides
    • Do not remove the keyboard fully, it is attached via a ribbon cable
  5. Compaq Presario CQ60 Keyboard Replacement, Detach ribbon cable: step 5, image 1 of 3 Compaq Presario CQ60 Keyboard Replacement, Detach ribbon cable: step 5, image 2 of 3 Compaq Presario CQ60 Keyboard Replacement, Detach ribbon cable: step 5, image 3 of 3
    • Lift keyboard slightly
    • Push each side of ribbon cable connector
    • Fully remove keyboard
Mike B
1,018 Reputation
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 24
All Time: 352
