Introduction
If the built-in webcam on your Compaq Mini 110 is giving you trouble, it is possible to remove it. Follow these comprehensive steps to get rid of an unwanted webcam.
Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
Remove the three screws in the silver tabs at the back of the keyboard.
Lift the keyboard away from the laptop.
Pry up the top plastic cover using a spudger.
These two tabs under the screen need to be pushed in with a spudger.
Remove the four screws that keep the bottom of the hinges attached to the base.
Pry off the top plastic cover of the display assembly.
The spudger may go all the way through to the screen-side of the cover. This is not a problem and won't damage anything.
After removing the cable from the back of the screen, detach the webcam assembly.
