Compaq Evo N1000v Rear Fan Replacement
  1. Compaq Evo N1000v Rear Fan Replacement, Rear Fan: step 1, image 1 of 1
    • Carefully remove the screws located inside the red circles.
  2. Compaq Evo N1000v Rear Fan Replacement: step 2, image 1 of 2 Compaq Evo N1000v Rear Fan Replacement: step 2, image 2 of 2
    • Next, you will need to push down the "F1" key with the spudger and push it under the silver LED display panel.
    • Push down on the spudger to lift the LED display upward.
    • Do this on both the left and right sides of the device as shown in the images.
  3. Compaq Evo N1000v Rear Fan Replacement: step 3, image 1 of 1
    • Completely remove the LED display panel from the device.
  4. Compaq Evo N1000v Rear Fan Replacement: step 4, image 1 of 1
    • Lift the keyboard up from the back end as shown in the image.
  5. Compaq Evo N1000v Rear Fan Replacement: step 5, image 1 of 1
    • Pull the keyboard slightly toward the screen of the device to reveal the connecting cable below.
  6. Compaq Evo N1000v Rear Fan Replacement: step 6, image 1 of 1
    • Follow the cable to its connection and use the grip tweezers to unlock the cable by grabbing the left side of the lock and pulling upward.
    • Repeat this action on the right side of the lock.
  7. Compaq Evo N1000v Rear Fan Replacement: step 7, image 1 of 1
    • Pull the keyboard upward to remove it from the device.
  8. Compaq Evo N1000v Rear Fan Replacement: step 8, image 1 of 1
    • Unscrew the 3 screws as shown in the photo.
  9. Compaq Evo N1000v Rear Fan Replacement: step 9, image 1 of 1
    • Remove the cable with the grip tweezers as shown in the photo.
  10. Compaq Evo N1000v Rear Fan Replacement: step 10, image 1 of 1
    • Remove the rear fan.
    • Repeat these steps in reverse order to install the new keyboard.
ryan
470 Reputation
2 Guides authored
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 8
All Time: 403
