Compaq Evo N1000v Palm Rest Replacement
  1. Compaq Evo N1000v Palm Rest Replacement, LED Cover: step 1, image 1 of 1
    • Flip the laptop over with the rear panel facing forward.
  2. Compaq Evo N1000v Palm Rest Replacement: step 2, image 1 of 1
    • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
  3. Compaq Evo N1000v Palm Rest Replacement: step 3, image 1 of 1
    • Flip the laptop back over with the front facing forward. Open the screen.
  4. Compaq Evo N1000v Palm Rest Replacement: step 4, image 1 of 1
    • Locate the F1 and F2 keys near the top left corner of the keyboard.
  5. Compaq Evo N1000v Palm Rest Replacement: step 5, image 1 of 1
    • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  6. Compaq Evo N1000v Palm Rest Replacement: step 6, image 1 of 1
    • Locate the Scroll and Pause keys near the top right corner of the keyboard.
  7. Compaq Evo N1000v Palm Rest Replacement: step 7, image 1 of 1
    • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  8. Compaq Evo N1000v Palm Rest Replacement: step 8, image 1 of 2 Compaq Evo N1000v Palm Rest Replacement: step 8, image 2 of 2
    • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
  9. Compaq Evo N1000v Palm Rest Replacement, Keyboard: step 9, image 1 of 1
    • Lift the back edge of the keyboard and pull towards the screen.
  10. Compaq Evo N1000v Palm Rest Replacement: step 10, image 1 of 1
    • Pull the cable and lift up to release.
  11. Compaq Evo N1000v Palm Rest Replacement: step 11, image 1 of 1
    • Remove the keyboard.
  12. Compaq Evo N1000v Palm Rest Replacement, Palm Rest: step 12, image 1 of 1
    • Flip the computer bottom side up with the rear facing forward.
  13. Compaq Evo N1000v Palm Rest Replacement: step 13, image 1 of 1
    • Remove the six screws shown in picture.
  14. Compaq Evo N1000v Palm Rest Replacement: step 14, image 1 of 1
    • Remove battery and then remove screw in metal support on case edge
    • Flip the computer top side up with the front facing you.
  15. Compaq Evo N1000v Palm Rest Replacement: step 15, image 1 of 1
    • Lift up the palm rest from the front edge and swing it towards the screen.
  16. Compaq Evo N1000v Palm Rest Replacement: step 16, image 1 of 1
    • Locate the first connector. Disconnect by firmly pulling up.
  17. Compaq Evo N1000v Palm Rest Replacement: step 17, image 1 of 1
    • Locate the second connector. Remove by firmly pulling up.
  18. Compaq Evo N1000v Palm Rest Replacement: step 18, image 1 of 1
    • Remove the palm rest.
Alex Hernandez
46 Reputation
4 Guides authored
Cal Poly, Team 29-74, Johann Spring 2010 Member of Cal Poly, Team 29-74, Johann Spring 2010
CPSU-JOHANN-S10S29G74
3 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 3,088
