Installing Compaq Evo 1000v Heat Sink
  1. Installing Compaq Evo 1000v Heat Sink, LED Cover: step 1, image 1 of 1
    • Flip the laptop over with the rear panel facing forward.
  2. Installing Compaq Evo 1000v Heat Sink: step 2, image 1 of 1
    • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
  3. Installing Compaq Evo 1000v Heat Sink: step 3, image 1 of 1
    • Flip the laptop back over with the front facing forward. Open the screen.
  4. Installing Compaq Evo 1000v Heat Sink: step 4, image 1 of 1
    • Locate the F1 and F2 keys near the top left corner of the keyboard.
  5. Installing Compaq Evo 1000v Heat Sink: step 5, image 1 of 1
    • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  6. Installing Compaq Evo 1000v Heat Sink: step 6, image 1 of 1
    • Locate the Scroll and Pause keys near the top right corner of the keyboard.
  7. Installing Compaq Evo 1000v Heat Sink: step 7, image 1 of 1
    • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  8. Installing Compaq Evo 1000v Heat Sink: step 8, image 1 of 2 Installing Compaq Evo 1000v Heat Sink: step 8, image 2 of 2
    • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
  9. Installing Compaq Evo 1000v Heat Sink, Keyboard: step 9, image 1 of 1
    • Lift the back edge of the keyboard and pull towards the screen.
  10. Installing Compaq Evo 1000v Heat Sink: step 10, image 1 of 1
    • Pull the cable and lift up to release.
  11. Installing Compaq Evo 1000v Heat Sink: step 11, image 1 of 1
    • Remove the keyboard.
  12. Installing Compaq Evo 1000v Heat Sink, Heat Sink: step 12, image 1 of 1
    • Locate the fan near the top left corner. It has three colored wires: yellow, red, and black.
    • Disconnect the cable connecting the fan to the system board.
  13. Installing Compaq Evo 1000v Heat Sink: step 13, image 1 of 1
    • Locate and remove the four screws in the copper plate.
  14. Installing Compaq Evo 1000v Heat Sink: step 14, image 1 of 1
    • Remove the heat spreader by pulling the whole assembly up out of the computer.
kim
59 Reputation
3 Guides authored
Cal Poly, Team 29-74, Johann Spring 2010 Member of Cal Poly, Team 29-74, Johann Spring 2010
CPSU-JOHANN-S10S29G74
3 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 4,011
