Commodore 64 VIC Chip Replacement
  1. Commodore 64 VIC Chip Replacement, Removing screws: step 1, image 1 of 3 Commodore 64 VIC Chip Replacement, Removing screws: step 1, image 2 of 3 Commodore 64 VIC Chip Replacement, Removing screws: step 1, image 3 of 3
    • 1. Remove three 6.75mm ph2 screw heads from the casing
    Ask FixBot
  2. Commodore 64 VIC Chip Replacement, Opening: step 2, image 1 of 2 Commodore 64 VIC Chip Replacement, Opening: step 2, image 2 of 2
    • 2. Split the case of the C64 open by pulling up on the case towards you
    • Do not pull too hard that you break the clips.
    Ask FixBot
  3. Commodore 64 VIC Chip Replacement, Detach the keyboard from the motherboard: step 3, image 1 of 2 Commodore 64 VIC Chip Replacement, Detach the keyboard from the motherboard: step 3, image 2 of 2
    • 1. Detach the multi-colored wire bundles that's connected to the motherboard
    Ask FixBot
  4. Commodore 64 VIC Chip Replacement, Pull up the VIC plate: step 4, image 1 of 2 Commodore 64 VIC Chip Replacement, Pull up the VIC plate: step 4, image 2 of 2
    • 2. Without using any tools prop up the metal VIC plate with both hands to expose the VIC chip.
    Ask FixBot
  5. Commodore 64 VIC Chip Replacement, Removing the Chip: step 5, image 1 of 2 Commodore 64 VIC Chip Replacement, Removing the Chip: step 5, image 2 of 2
    • 3. Use a Phillips screwdriver to pry up the VIC chip. Then, use your hands and with small pressure pull it away to remove it from the motherboard.
    • You can insert a new VIC chip by making it clip back in on the board
    Ask FixBot
2 other people completed this guide.
Silvanus Clarke
677 Reputation
5 Guides authored
USF Tampa, Team 13-6, Staggers Fall 2014 Member of USF Tampa, Team 13-6, Staggers Fall 2014
USFT-STAGGERS-F14S13G6
4 Members
15 Guides authored
1 Guide Comment
It's awesome to see that people care enough about these machines to make repair guides about them! Great job!
[deleted] - Reply Share
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 59
All Time: 5,565
