This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Coffee Machine minimal water output after months of disuse
  1. Coffee Machine minimal water output after months of disuse, Coffee Machine minimal water output after months of disuse: step 1, image 1 of 3 Coffee Machine minimal water output after months of disuse, Coffee Machine minimal water output after months of disuse: step 1, image 2 of 3 Coffee Machine minimal water output after months of disuse, Coffee Machine minimal water output after months of disuse: step 1, image 3 of 3
    • Sometimes Nespresso coffee machines will not fill with water after months of not using them. It is a very common issue with this type of coffee machine, as the interior tubing dries out and the machine itself cannot refill itself with water. We will explore a homemade method to ensure the machine feeds correctly from the water reservoir
    • 1. Remove the water reservoir
  2. Coffee Machine minimal water output after months of disuse: step 2, image 1 of 1
    • We need the following two things for this procedure:
    • A syringe, the bigger the better. In this case I use a 20ml one.
  3. Coffee Machine minimal water output after months of disuse: step 3, image 1 of 3 Coffee Machine minimal water output after months of disuse: step 3, image 2 of 3 Coffee Machine minimal water output after months of disuse: step 3, image 3 of 3
    • 2nd: A piece of foam or sponge. Ideally as rigid as possible. A piece of wide rubber that exceeds the diameter of the syringe can also work.
  4. Coffee Machine minimal water output after months of disuse: step 4, image 1 of 3 Coffee Machine minimal water output after months of disuse: step 4, image 2 of 3 Coffee Machine minimal water output after months of disuse: step 4, image 3 of 3
    • We will make a hole in the sponge up until half of its length so that the mouth of the syringe can rest in it.
    • We will make a small fissure so that when we insert the syringe, the tip will protrude slightly beyond the sponge.
  5. Coffee Machine minimal water output after months of disuse: step 5, image 1 of 1
    • Using the syringe, we will fill the hole where the water reservoir rests.
  6. Coffee Machine minimal water output after months of disuse: step 6, image 1 of 2 Coffee Machine minimal water output after months of disuse: step 6, image 2 of 2
    • Support the sponge/foam using the syringe, completely covering the hole
    • In the included images we can see that the syringe is slightly leaning towards a side. I have chosen to make the hole be tilted inside of the sponge since this will make it work with the highest number of coffee machines, since many of them protrude from the rear and the syringe could be obstructed by the machine.
    • This way is the most versatile way of doing it that maximizes compatibility between different models.
  7. Coffee Machine minimal water output after months of disuse: step 7, image 1 of 3 Coffee Machine minimal water output after months of disuse: step 7, image 2 of 3 Coffee Machine minimal water output after months of disuse: step 7, image 3 of 3
    • 1. Having positioned the syringe, press down so that the water does not escape through the side.
    • 2. Press the button. In this case, the large cup one, for example.
    • 3. Press the piston down completely while the water pump is running.
    • 4. When the syringe is completely depleted, press the button again to stop the pump.
    • 5. Remove the syringe.
  8. Coffee Machine minimal water output after months of disuse: step 8, image 1 of 1
    • Using the syringe, fill the hole where the water reservoir rests.
  9. Coffee Machine minimal water output after months of disuse: step 9, image 1 of 1
    • Put the filled water reservoir in its place.
  10. Coffee Machine minimal water output after months of disuse: step 10, image 1 of 3 Coffee Machine minimal water output after months of disuse: step 10, image 2 of 3 Coffee Machine minimal water output after months of disuse: step 10, image 3 of 3
    • With the water reservoir correctly placed, lift the capsule lever completely.
    • Press the large coffee button.
    • When water starts to flow from the reservoir, close the lever to ensure that water begins to flow.
    • Our problem is hereby solved.
    • If this method doesn't work, we can try it again. If it doesn't work after several attempts, then we must take it apart to manually clear the water piping.
    • This link will elaborate on this second option.
Finish Line
Special thanks to these translators:
es en
90%
David is helping us fix the world! Want to contribute?
Start translating ›
Carlos López (España - Spain)
54,924 Reputation
165 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,500 Guides authored
0 Comments
Past 24 Hours: 15
Past 7 Days: 70
Past 30 Days: 207
All Time: 528
