Laser Lens Cleaning
  1. Laser Lens Cleaning, Top Panel: step 1, image 1 of 2 Laser Lens Cleaning, Top Panel: step 1, image 2 of 2
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
  2. Laser Lens Cleaning: step 2, image 1 of 2 Laser Lens Cleaning: step 2, image 2 of 2
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
  3. Laser Lens Cleaning, Laser Lens Cleaning: step 3, image 1 of 2 Laser Lens Cleaning, Laser Lens Cleaning: step 3, image 2 of 2
    • Locate the lens on the disc drive.
    • Make sure that there is no dust on or near the player and area you are working on. Dust can get on the lens and scratch it while you are cleaning. It is very important that the lens is not damaged because the lens is used to read the discs.
    • Dip one end of a cotton swab in rubbing alcohol.
    • Lightly dab the swab on the lens. Be very gentle.
    • Let the lens dry before replacing the top plate of the DVD player.
12 other people completed this guide.
Nathan Klammer
461 Reputation
3 Guides authored
Cal Poly, Team 21-20, Maness Fall 2011 Member of Cal Poly, Team 21-20, Maness Fall 2011
CPSU-MANESS-F11S21G20
4 Members
7 Guides authored
3 Comments
This item was not appropriate, thank you for trying.
bigd734 - Reply
Works on Samsung's box(home theater), thank you!
CarlBraun - Reply
It worked on my cheap player. This unit is on 24/7. The dust in the house is heavy and smokers so the fix is cheap and I picked up a few things. Thanks
Seeker - Reply
Past 24 Hours: 8
Past 7 Days: 62
Past 30 Days: 342
All Time: 48,411
