Introduction
This guide shows how to remove and replace the control switch on the Clarke EZ-8 floor sander.
Step 1 Disconnect all power cables
Careful: step 1 is sourced from a guide that's marked as in-progress.
Slide the collar on the control link arm up until the two halves of the arm detach from one another.
Use a socket wrench with a deep 9/16" socket to remove the retaining nut and star washer from the control switch toggle.
Use a Phillips #2 screwdriver to remove the six screws on the control housing—three on either side.
Lift the control housing up and swing it open so the wiring panel inside is accessible.
Use a #2 Phillips head screwdriver to remove the following three screws from the wiring panel:
Two 10-32 x 3/8" screws
One 8-32 x 3/8" screw
Remove the ring and fork terminals from the screws.
Pull and gently wiggle the control switch to remove it from its mounting hole in the control housing.
9 other people completed this guide.
2 Comments
Well Done, steps are clear and EZ 8 to follow!
Thank you excellent instruction
