This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Clamp Press
View statistics:
Past 24 Hours:
0
Past 7 Days:
8
Past 30 Days:
38
All Time:
211
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Clamp Press
      • Clean the Faces
      Ask FixBot
      • Place the tang against the bottom of the hammer
      Ask FixBot
      • Without applying pressure to the die, tighten the upper screws of the mold holder
      Ask FixBot
      • Apply light pressure with the hammer on top of the mold base and secure the bottom part of the mold base
      Ask FixBot
      • Clean the upper and lower base of the shock plate
      Ask FixBot
      • Release the pressure from the springs and set to zero
      Ask FixBot
      • Place the die and adjust it until it hits the stop using the front screws
      Ask FixBot
      • Tighten the die splints
      Ask FixBot
      • Attach the punch and the extraction ruler
      Ask FixBot
      • Clean the mold carrier and cutting carriage faces
      Ask FixBot
      • Measure the blade height on the cutting carriage
      • Note: Lower blade on the plane of the cutting carriage
      • Note: Assemble the upper blade 0.1 mm lower than the stops
      Ask FixBot
      • Place the cutting carriage in the mold holder
      Ask FixBot
      • Raise the hammer using the screw
      Ask FixBot
      • Insert spacer shims according to the size of the clamp to be made
      Ask FixBot
      • Press the cutting carriage and separators against the die
      Ask FixBot
      • Secure the bottom of the car to the mold carrier base
      Ask FixBot
      • Attach the upper part to the top of the mold holder
      Ask FixBot
      • Insert the corresponding size guide and feed the band through
      Ask FixBot
      • Lower the hammer using the screw until it touches the stops and cuts the band
      • If it does not cut, shim the upper blade
      • Verify again that the lower blade is flush with the cutting carriage using the caliper as a straightedge
      Ask FixBot
      • Perform the bend and check the punch height
      Ask FixBot
Guide for Assembling the Mold Holder, Die, and Cutting Carriage on Presses.
Mateus Almeida
301 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 38
All Time: 211
