Citizen Ecodrive Watch Battery Replacement
  1. Citizen Ecodrive Watch Battery Replacement, Battery: step 1, image 1 of 1
    • Remove pin from watch band link to obtain easier access to the back of the watch.
  2. Citizen Ecodrive Watch Battery Replacement: step 2, image 1 of 2 Citizen Ecodrive Watch Battery Replacement: step 2, image 2 of 2
    • Using the adjustable wrench, unscrew the back face of the watch.
  3. Citizen Ecodrive Watch Battery Replacement: step 3, image 1 of 1
    • Using the sim removal tool, carefully pry the capacitor from its current location.
  4. Citizen Ecodrive Watch Battery Replacement: step 4, image 1 of 2 Citizen Ecodrive Watch Battery Replacement: step 4, image 2 of 2
    • Replace the capacitor with the new lithium capacitor.
    • Make sure the positive side is facing upward.
    • When reinserting capacitor, make sure the brass connector is inserted into the inlet of the battery slot.
  5. Citizen Ecodrive Watch Battery Replacement: step 5, image 1 of 1
    • To close the back, use a watch press. (The watch press tool and a set of dies costs about $15.)
    • Pick one of the dies that just fits the outer edge of the bezel for the front side, and pick another one that just fits the outer edge of the back casing. Attach the die for the back on the top (the lever of the watch press) and the die for the face on the bottom (the base of the watch press).
    • Place the watch face down. Arrange the seal (if any), and put the watch back gently into position.
    • Squeeze the tool slowly and firmly until you hear it click into place. Some watches do not click, so check the progress as you squeeze.
  6. Citizen Ecodrive Watch Battery Replacement: step 6, image 1 of 2 Citizen Ecodrive Watch Battery Replacement: step 6, image 2 of 2
    • Pull the knob out for thirty seconds to place the watch in its "all reset" mode.
To reassemble your device, follow the steps in reverse order.
48 other people completed this guide.
43 Comments
How about citizen c605? How to open for replace capacitor?cheers
Citizen alex - Reply
Before doing any repairs it might be a good idea to do these:
1. Place the watch to bright sunshine for one full day the dial facing straight to the sun.
2. After the sun treatment pull the knop fully out and keep it that way for 30 seconds (or more).
3. Press the knop back in and wait for 10 seconds.
4. If the watch now works normally, you saved the battery price and your fixing work…
5. If not, you unfortunately have to do as instructed here.
Good luck!
Seppo Nikkilä - Reply
Does the Capacitor of an Eco-drive watch has a tendency to leak?
citizen ph - Reply
No Generally speaking electrolitic capacitors dry out from old age but these just lose their ability to hold a charge…. no leaking
Jeff Kohlmann -
Where can I get an adjustable wrench like the one in the picture?
Timothy Zorn - Reply
Past 24 Hours: 69
Past 7 Days: 605
Past 30 Days: 2,949
All Time: 273,197
