Circo Monkey Alarm Clock Motor Replacement
  1. Circo Monkey Alarm Clock Motor Replacement, Screw Removal: step 1, image 1 of 2 Circo Monkey Alarm Clock Motor Replacement, Screw Removal: step 1, image 2 of 2
    • Remove all six 7.3 mm screws with a #00 Phillips head screwdriver.
  2. Circo Monkey Alarm Clock Motor Replacement, Splitting the Shell in Half: step 2, image 1 of 1
    • Firmly pull each half apart.
  3. Circo Monkey Alarm Clock Motor Replacement, Clock Motor: step 3, image 1 of 2 Circo Monkey Alarm Clock Motor Replacement, Clock Motor: step 3, image 2 of 2
    • Once the clock is apart, carefully pull both halves until the clock is in two separate halves.
  4. Circo Monkey Alarm Clock Motor Replacement: step 4, image 1 of 2 Circo Monkey Alarm Clock Motor Replacement: step 4, image 2 of 2
    • Unscrew the two 2 mm screws with a #00 Phillips Head screwdriver.
  5. Circo Monkey Alarm Clock Motor Replacement: step 5, image 1 of 3 Circo Monkey Alarm Clock Motor Replacement: step 5, image 2 of 3 Circo Monkey Alarm Clock Motor Replacement: step 5, image 3 of 3
    • Pull off the clock motor housing and un-clip the 4 clips on each side.
  6. Circo Monkey Alarm Clock Motor Replacement: step 6, image 1 of 1
    • Repair any lose or misplaced gears or wiring.
3 other people completed this guide.
Frank
151 Reputation
1 Guide authored
USF Tampa, Team 19-1, Blackwell Winter 2015 Member of USF Tampa, Team 19-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G1
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 977
