Cirago M9030 Battery Replacement
    1. Cirago M9030 Battery Replacement, Cover: step 1, image 1 of 1
      • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
      Ask FixBot
    2. Cirago M9030 Battery Replacement: step 2, image 1 of 1
      • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
      • Remove the warranty sticker across the bottom.
      Ask FixBot
    3. Cirago M9030 Battery Replacement: step 3, image 1 of 2 Cirago M9030 Battery Replacement: step 3, image 2 of 2
      • Gently take the cover apart using your hands separating the top and bottom.
      • The outer shell is expected to easily come apart.
      Ask FixBot
    1. Cirago M9030 Battery Replacement, Hard Drive: step 4, image 1 of 1
      • Make sure that the screen of the device is facing down.
      Ask FixBot
    2. Cirago M9030 Battery Replacement: step 5, image 1 of 3 Cirago M9030 Battery Replacement: step 5, image 2 of 3 Cirago M9030 Battery Replacement: step 5, image 3 of 3
      • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
      • Raise the bottom edge of the hard drive 15 degrees up from the device.
      Ask FixBot
    3. Cirago M9030 Battery Replacement: step 6, image 1 of 3 Cirago M9030 Battery Replacement: step 6, image 2 of 3 Cirago M9030 Battery Replacement: step 6, image 3 of 3
      • Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
      Ask FixBot
    1. Cirago M9030 Battery Replacement, IDE Connector: step 7, image 1 of 2 Cirago M9030 Battery Replacement, IDE Connector: step 7, image 2 of 2
      • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
      Ask FixBot
    2. Cirago M9030 Battery Replacement: step 8, image 1 of 1
      • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
      Ask FixBot
    3. Cirago M9030 Battery Replacement: step 9, image 1 of 2 Cirago M9030 Battery Replacement: step 9, image 2 of 2
      • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
      • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
      Ask FixBot
    4. Cirago M9030 Battery Replacement: step 10, image 1 of 1
      • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
      Ask FixBot
    5. Cirago M9030 Battery Replacement: step 11, image 1 of 2 Cirago M9030 Battery Replacement: step 11, image 2 of 2
      • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
      • Completely remove the IDE connector from the device.
      Ask FixBot
    1. Cirago M9030 Battery Replacement, Motherboard: step 12, image 1 of 2 Cirago M9030 Battery Replacement, Motherboard: step 12, image 2 of 2
      • Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard.
      • Completely remove the motherboard.
      • The motherboard should slide out easily.
      Ask FixBot
    1. Cirago M9030 Battery Replacement, Button Module: step 13, image 1 of 1
      • Set aside the front cover.
      • Flip over the motherboard.
      • Using the Philips #00 screwdriver, remove the three 4mm long screws holding down the button module.
      Ask FixBot
    2. Cirago M9030 Battery Replacement: step 14, image 1 of 3 Cirago M9030 Battery Replacement: step 14, image 2 of 3 Cirago M9030 Battery Replacement: step 14, image 3 of 3
      Tool used on this step:
      Buy
      • Using the tweezers, lift up the button module to a 180 degree angle.
      • Leave the button module attached by the ribbon.
      • Flip over the motherboard with the button module still attached.
      Ask FixBot
    3. Cirago M9030 Battery Replacement: step 15, image 1 of 3 Cirago M9030 Battery Replacement: step 15, image 2 of 3 Cirago M9030 Battery Replacement: step 15, image 3 of 3
      • Fold the button module over the motherboard.
      • Using the tweezers, remove the ribbon pin.
      • The ribbon pin should snap completely off of the motherboard.
      Ask FixBot
    4. Cirago M9030 Battery Replacement: step 16, image 1 of 2 Cirago M9030 Battery Replacement: step 16, image 2 of 2
      • The ribbon should easily detach from the motherboard.
      Ask FixBot
    1. Cirago M9030 Battery Replacement, Battery: step 17, image 1 of 2 Cirago M9030 Battery Replacement, Battery: step 17, image 2 of 2
      • Flip over the motherboard so the screen faces up.
      • Carefully slide the battery off of the motherboard.
      • Leave the battery cable connected to the motherboard.
      Ask FixBot
    2. Cirago M9030 Battery Replacement: step 18, image 1 of 3 Cirago M9030 Battery Replacement: step 18, image 2 of 3 Cirago M9030 Battery Replacement: step 18, image 3 of 3
      • Place two fingers on the battery connectors and gently pull the power cable connector completely out from the motherboard.
      • Do not pull directly on the wire as it may damage the connector.
      Ask FixBot
Ryan Sutardji
171 Reputation
7 Guides authored
Cal Poly, Team 1-4, Regan SU 2012 Member of Cal Poly, Team 1-4, Regan SU 2012
CPSU-REGAN-SU12S1G4
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 94
All Time: 1,726
