Chromo Inc. T2 Internal Speaker Replacement
  1. Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: step 1, image 1 of 3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: step 1, image 2 of 3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: step 1, image 3 of 3
    • Using your Plastic Opening Tool, place it in between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Internal Speaker Replacement, Turn it around: step 2, image 1 of 1
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: step 3, image 1 of 3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: step 3, image 2 of 3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: step 3, image 3 of 3
    • Remove two strips of tape: One holding down the wires and the other holding down the internal speaker.
  4. Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: step 4, image 1 of 3 Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: step 4, image 2 of 3 Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: step 4, image 3 of 3
    • Using a Soldering Iron, desolder both speaker wires. Once both wires are desoldered, your Internal Speaker is now ready for replacement!
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
Ismael DeLuna
637 Reputation
5 Guides authored
USF Tampa, Team 15-1, Watkins Winter 2015 Member of USF Tampa, Team 15-1, Watkins Winter 2015
USFT-WATKINS-W15S15G1
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 8
All Time: 216
