Place your Plastic Opening Tool between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
After separating the case and screen, turn your screen face down so you can see the internal parts!
Using the Spudger, going between the battery and screen, pry the battery off from the tablet.
Note: This will require a little extra force due to the tape holding down the battery!
