Community-Contributed Guide
Introduction
Go to step 1 ↓This guide will show you how to replace the back panel of the google pixel (2013)
Tools
Flip your Chromebook Pixel over onto its back
Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
Using a small Philips screwdriver, remove the four screws under the pads
Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
Locate the write protect screw
Remove it and you can begin flashing your BIOS!
To reassemble your device, follow these instructions in reverse order. Don't forget to firmly press down on the rubber feet so the adhesive reseals over the screws!
🔓 Did you successfully unlock your Pixel?
If this guide helped you open your Chromebook Pixel safely and locate the write-protect screw, please scroll down and click the blue "Give the author +30 points!" button!
As an independent community author, your quick click costs nothing but deposits the full +30 reputation points directly into my profile, which will finally push me past my major site-wide milestone. Thanks for supporting open repair knowledge, and happy bios-flashing!
