Up to 20% off select tools
ChromeOS Flex USB Creation
View statistics:
Past 24 Hours:
Past 7 Days:
Past 30 Days:
All Time:
55
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite only guide to create a USB installer for ChromeOS Flex.
    1. ChromeOS Flex USB Creation, Connect a USB drive: step 1, image 1 of 2 ChromeOS Flex USB Creation, Connect a USB drive: step 1, image 2 of 2
      • Connect a USB flash drive or SD card with at least 16 GB of capacity to the fastest available port on the computer.
      • Use a USB 3 drive connected to a USB 3 port for faster installation. Rectangular USB 3 ports are usually colored blue and/or labeled SuperSpeed (SS).
      Ask FixBot
    2. ChromeOS Flex USB Creation, Write the USB installer: step 2, image 1 of 3 ChromeOS Flex USB Creation, Write the USB installer: step 2, image 2 of 3 ChromeOS Flex USB Creation, Write the USB installer: step 2, image 3 of 3
      • Add the Chromebook Recovery Utility extension to your browser.
      • Compatible browsers include Brave, Chrome, Edge, and Opera. If you're using another browser, like Firefox, skip the next two steps for an alternate procedure.
      • Open the extension and click Get started.
      • Click Select a model from a list.
      • From the drop‑down menus, select Google ChromeOS Flex, then ChromeOS Flex. Click Continue.
      Ask FixBot
    3. ChromeOS Flex USB Creation: step 3, image 1 of 3 ChromeOS Flex USB Creation: step 3, image 2 of 3 ChromeOS Flex USB Creation: step 3, image 3 of 3
      • This step will erase and overwrite the chosen USB drive/SD card with the ChromeOS Flex installer. Unplug all other external storage so you don't pick the wrong one.
      • Select the USB drive or SD card you want to use from the drop‑down menu.
      • Double‑check that the device selected is the one you want erased and ChromeOS Flex written to. Then click Create now.
      • Wait for the process to complete, and click Allow or Yes to any relevant pop‑ups.
      • On Windows, close or click Cancel on any pop‑ups asking you to format the disk.
      • Once complete, click Done.
      • If the utility doesn't say Success, follow the next two steps for an alternate method. Otherwise, you're done!
      Ask FixBot
    4. ChromeOS Flex USB Creation, [Alternate] Download ChromeOS Flex: step 4, image 1 of 2 ChromeOS Flex USB Creation, [Alternate] Download ChromeOS Flex: step 4, image 2 of 2
      • Click here to download the latest version of ChromeOS Flex.
      • Locate the downloaded .zip file and extract it somewhere you can easily find in the next step.
      • On Windows, right‑click the .zip file, select Extract All..., choose a location, then click Extract.
      • On MacOS, double‑click the .zip file in Finder.
      • The Safari browser may automatically extract it.
      • The extracted installer file will end in .bin.
      • A .bin file is a complete "blueprint" of the operating system installer. Instead of simply copying and pasting this file onto your USB drive, you'll use a tool in the next step to write it to the USB drive so a computer can start up from it.
      Ask FixBot
    5. ChromeOS Flex USB Creation, Write to the USB: step 5, image 1 of 3 ChromeOS Flex USB Creation, Write to the USB: step 5, image 2 of 3 ChromeOS Flex USB Creation, Write to the USB: step 5, image 3 of 3
      • This step will erase and overwrite the chosen USB drive or SD card with the ChromeOS Flex installer. Unplug all other storage devices so you don't pick the wrong one.
      • Download and install Fedora Media Writer. Click the file ending in .exe for Windows and the one ending in .dmg for MacOS (use arm64 for Apple Silicon).
      • Launch Fedora Media Writer.
      • Click Select .iso file then click Next.
      • Select the .bin file by clicking the Select... button and clicking it in the File Explorer/Finder window that pops up.
      • Verify the selected USB Drive/SD card is the one you want to use.
      • Double-check everything is correct, then select Write. A window will pop up asking to confirm. Select Write to erase the chosen drive and write the ChromeOS Flex installer to it.
      Ask FixBot
Finish Line
Nick Schultz
71,208 Reputation
363 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 55
