Dell Inspiron N5030 Hard Drive Replacement
    1. Dell Inspiron N5030 Hard Drive Replacement, Battery: step 1, image 1 of 2 Dell Inspiron N5030 Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Turn the computer over on its back so the battery compartment faces towards you.
      • Place your fingers on the small buttons with arrows pointing outwards.
      • Push and slide the buttons outward to unlock the battery compartment.
      Ask FixBot
    2. Dell Inspiron N5030 Hard Drive Replacement: step 2, image 1 of 2 Dell Inspiron N5030 Hard Drive Replacement: step 2, image 2 of 2
      • Grab the battery and pull it towards yourself.
      • Remove the battery.
      Ask FixBot
    1. Dell Inspiron N5030 Hard Drive Replacement, Keyboard: step 3, image 1 of 1
      • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
      Ask FixBot
    2. Dell Inspiron N5030 Hard Drive Replacement: step 4, image 1 of 1
      • Flip over the laptop and open it so that the screen faces you.
      Ask FixBot
    3. Dell Inspiron N5030 Hard Drive Replacement: step 5, image 1 of 1
      • Use the plastic opening tool and your fingers to pry off the top panel.
      • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
      Ask FixBot
    4. Dell Inspiron N5030 Hard Drive Replacement: step 6, image 1 of 1
      • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
      • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
      Ask FixBot
    5. Dell Inspiron N5030 Hard Drive Replacement: step 7, image 1 of 1
      • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
      Ask FixBot
    6. Dell Inspiron N5030 Hard Drive Replacement: step 8, image 1 of 1
      • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
      Ask FixBot
    7. Dell Inspiron N5030 Hard Drive Replacement: step 9, image 1 of 1
      • Remove the top keyboard panel.
      Ask FixBot
    1. Dell Inspiron N5030 Hard Drive Replacement, Hard Drive: step 10, image 1 of 1
      • Position your fingers on two sides of the hard drive in the bottom right corner of the computer.
      Ask FixBot
    2. Dell Inspiron N5030 Hard Drive Replacement: step 11, image 1 of 1
      • Firmly push and slide the hard drive toward the right side of the laptop.
      Ask FixBot
    3. Dell Inspiron N5030 Hard Drive Replacement: step 12, image 1 of 1
      • Lift and remove the hard drive from the laptop.
      Ask FixBot
13 other people completed this guide.
Charles
582 Reputation
2 Guides authored
Cal Poly, Team 10-59, Amido Spring 2014 Member of Cal Poly, Team 10-59, Amido Spring 2014
CPSU-AMIDO-S14S10G59
4 Members
60 Guides authored
3 Guide Comments
It is better and easier to take the keyboard out first to enable safe removal and fitting of the keyboard ribbon cables, Lever panel out once screws are removed as described above. However thanks for the pointers!
Charles Mott - Reply Share
The connector in step 7 is actually the connector for the speakers. The keyboard connector is the long white one with the brownish top which appears to be open in the photo. The keyboard cable is a flat wide cable that fits in the connector. In the photograph the keyboard cable has already been removed.
James Sanders - Reply Share
I want to repeat what Charles Mott said. The proper way to do this is to unclip the keyboard providing easy access to all the cable connections. The people that say Dell designed this poorly don’t know they can just unclip the keyboard (three little tabs).
morsemichaelh@gmail.com - Reply Share
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 109
All Time: 10,939
