Nikon D5000 Speaker Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
97
All Time:
1,513
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your camera stops making noise, or the sound is distorted, you may want to inspect or replace the speaker.
Tools
    1. Nikon D5000 Speaker Replacement, Back Panel: step 1, image 1 of 3 Nikon D5000 Speaker Replacement, Back Panel: step 1, image 2 of 3 Nikon D5000 Speaker Replacement, Back Panel: step 1, image 3 of 3
      • The battery door has been removed for clarity, but is not necessary. See this guide for how to remove it.
      • Unscrew the eight Phillips #00 screws on the back panel:
      • Two 2.5x6mm screws above the screen.
      • One 3x6mm screw on the upper part of each side (two total; right side shown).
      • One 3x7.5mm screw on the lower part of each side (two total).
      • Two 3x4.5mm screws on the bottom.
      Ask FixBot
    2. Nikon D5000 Speaker Replacement: step 2, image 1 of 3 Nikon D5000 Speaker Replacement: step 2, image 2 of 3 Nikon D5000 Speaker Replacement: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Pull the back panel up, then tilt it back. There will be two cables still holding it on.
      • Doing this will also release the connector cover on the left side. Set it aside for now, but remember to reinstall it later.
      • Disconnect the ribbon cable by flipping the black tab up, then pulling the cable out.
      • This procedure also applies to all of the other ribbon cables in the D5000.
      • Pull out the other connector by lifting it up with tweezers, or by prying it out. Fingernails also work well.
      Ask FixBot
    1. Nikon D5000 Speaker Replacement, Speaker: step 3, image 1 of 2 Nikon D5000 Speaker Replacement, Speaker: step 3, image 2 of 2
      • The speaker is mounted to the underside of the back panel. There is a a metal shield that holds it on.
      • Remove the four Phillips #00 screws securing the shield:
      • Three silver 3x4mm screws.
      • One black 3x3mm screw.
      • Remove the shield.
      • With the shield off, the navigation buttons and "Lv" button are free to move and rotate. Check alignment before replacement.
      Ask FixBot
    2. Nikon D5000 Speaker Replacement: step 4, image 1 of 1
      • Lift the blue tape on the ribbon cable.
      • Desolder the two leads to the speaker.
      Ask FixBot
    3. Nikon D5000 Speaker Replacement: step 5, image 1 of 1
      • Pry the speaker out of its cavity.
      Ask FixBot
Jacob Rardin
1,472 Reputation
6 Guides authored
Cal Poly, Team 13-28, Maness Spring 2014 Member of Cal Poly, Team 13-28, Maness Spring 2014
CPSU-MANESS-S14S13G28
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 97
All Time: 1,513
