Chipolo One Point battery Replacement
      • Insert a flexible steel blade carefully into the seam of the casing. Work slowly around the edge until the casing begins to separate.
      Ask FixBot
      • After opening the casing, locate the CR2032 coin cell battery.
      Ask FixBot
      • Do not try to lift the CR2032 battery out by force. Do not bend the battery retainer upward. This can break the battery retainer.
      Ask FixBot
      • Carefully rotate the thin battery retainer out of the way. The battery should become loose once the strip is no longer holding it.
      Ask FixBot
      • Remove the old CR2032 battery after the battery retainer has been moved aside.
      Ask FixBot
      • Insert the new CR2032 battery in the same orientation as the old one. Make sure the battery sits flat in its holder.
      Ask FixBot
      • Rotate the thin battery retainer back into its original position. Make sure it holds the battery without being bent or stressed.
      Ask FixBot
      • Align the casing halves. Press them together carefully until the casing closes.
      Ask FixBot
After replacing the CR2032 battery, make sure the battery sits flat and the thin retaining strip is back in its original position.
Close the Chipolo ONE Point casing carefully and check that the tracker powers on normally.
The key point is simple:
Do not pry the battery upward. Rotate the thin retaining strip out of the way, then remove the battery.
Antti Silenius
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 87
All Time: 141
