HP Envy x360 m6-aq105dx Audio Jack Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
53
All Time:
790
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This piece of the device is responsible for the connection between headphones and the computer. If this piece of the device isn’t working, then it isn’t possible to hear sound from the laptop unless it is playing out loud from the speakers. This guide will show how to replace a faulty Audio Jack.
Tools
    1. HP Envy x360 m6-aq105dx Audio Jack Replacement, Back Cover: step 1, image 1 of 1
      • Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
      • Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
      • Remove the six 5.2 mm screws using the Torx T5 screwdriver.
      Ask FixBot
    2. HP Envy x360 m6-aq105dx Audio Jack Replacement: step 2, image 1 of 1
      • Light to moderate force is required to remove the back cover.
      • Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
      Ask FixBot
    1. HP Envy x360 m6-aq105dx Audio Jack Replacement, Audio Jack: step 3, image 1 of 1
      • Attach the grounding bracelet's clip to the frame of the laptop, then put on the grounding bracelet.
      • Remove the two 4.6 mm screws using the Phillips #0 screwdriver.
      • Remove the one 4.4mm screw using the Phillips #0 screwdriver.
      • Remove the one 2.8mm screws securing the audio jack/power button board using the Phillips #0 screwdriver.
      Ask FixBot
    2. HP Envy x360 m6-aq105dx Audio Jack Replacement: step 4, image 1 of 2 HP Envy x360 m6-aq105dx Audio Jack Replacement: step 4, image 2 of 2
      • Place the blue plastic opening tool on top of the blue data ribbon and under the connector. Lift up on the blue plastic opening tool to open the connector.
      • Remove the blue data ribbon from the audio board.
      Ask FixBot
    3. HP Envy x360 m6-aq105dx Audio Jack Replacement: step 5, image 1 of 2 HP Envy x360 m6-aq105dx Audio Jack Replacement: step 5, image 2 of 2
      • Remove the audio jack motherboard from the computer.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 53
All Time: 790
