Shop the Holiday Gift Guide
Charging Port Installation
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
19
All Time:
110
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. Charging Port Installation, Connect a charging cable: step 1, image 1 of 2 Charging Port Installation, Connect a charging cable: step 1, image 2 of 2
      • Plugging in a charging cable helps ensure the port is properly aligned, as well as making it significantly easier to install the screws. Make sure the cable is not plugged into a power source.
      • Align the charging port with its screw holes and plug in a charging cable, making sure the microphone cable goes over the top of the port.
      Ask FixBot
    2. Charging Port Installation, Install the charging port screws: step 2, image 1 of 3 Charging Port Installation, Install the charging port screws: step 2, image 2 of 3 Charging Port Installation, Install the charging port screws: step 2, image 3 of 3
      Tool used on this step:
      Magnetizer / Demagnetizer
      $8.99
      Buy
      • Install the four screws securing the charging port:
      • Two 3.7 mm‑long Torx Plus 3IP screws
      • Two 2.2 mm‑long Torx Plus 1IP screws
      • If you're using the nut driver method, you may need to use a magnetizer to get the screws to stick to the bit.
      Ask FixBot
    3. Charging Port Installation, Unplug the charging cable: step 3, image 1 of 1
      • Unplug the charging cable.
      Ask FixBot
    4. Charging Port Installation, Secure the microphone cable: step 4, image 1 of 3 Charging Port Installation, Secure the microphone cable: step 4, image 2 of 3 Charging Port Installation, Secure the microphone cable: step 4, image 3 of 3
      • Flip the microphone cable down over the top of the charging port so the alignment peg goes through its cutout.
      Ask FixBot
    5. Charging Port Installation: step 5, image 1 of 2 Charging Port Installation: step 5, image 2 of 2
      • Use the point of a spudger to gently press the microphone cable onto the port, securing it with the leftover adhesive on the cable.
      Ask FixBot
Finish Line
Spencer Day
210,389 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 19
All Time: 110
