Changing the blade of a 460BSP500E-3 lawn mower
  1. Changing the blade of a 460BSP500E-3 lawn mower, Security: step 1, image 1 of 2 Changing the blade of a 460BSP500E-3 lawn mower, Security: step 1, image 2 of 2
    • Unplug the anti-parasitic spark plug
  2. Changing the blade of a 460BSP500E-3 lawn mower, Tilt the lawn mower: step 2, image 1 of 2 Changing the blade of a 460BSP500E-3 lawn mower, Tilt the lawn mower: step 2, image 2 of 2
    • Always tilt the lawn mower to the exhaust side.
  3. Changing the blade of a 460BSP500E-3 lawn mower, Tools Needed: step 3, image 1 of 1
    • Tools needed to replace the blade:
    • 17mm wrench
    • Blade lock
    • Position and affix the blade lock on the mower deck. Ensure the blade is positioned inside the lock.
    • Unscrew the blade's fixing bolt with the 17mm wrench, turning counter clock-wise.
    • Remove the bolt and the blade.
    • Make sure to check the state of the blade support (blade adapter). If it is damaged, replace it imperatively.
    • Put in place the new blade and screw the fixing bolt back. Use your hand, turning in clockwise, and finish tightening with the 17mm wrench.
    • Remove the blade lock, reposition the lawn mower upright, and replug the spark plug wire on the spark plug.
Finish Line
Special thanks to these translators:
fr en
100%
Annie is helping us fix the world! Want to contribute?
Start translating ›
iRobot
1 Reputation
636 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 30
All Time: 1,095
