Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W, 19L, 3800L/h)
  1. Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Tools Needed: step 1, image 1 of 3 Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Tools Needed: step 1, image 2 of 3 Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Tools Needed: step 1, image 3 of 3
    • Before fiddling with the booster pump, verify that it is not plugged in.
    • Tools Needed:
    • Flathead screwdriver
    • Flat wrench (size 14mm and 12mm)
    • L-shaped socket wrench (size 14mm)
    • Flat wrench (size 28mm) or an adjustable wrench
  2. Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Depressurize the reservoir: step 2, image 1 of 3 Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Depressurize the reservoir: step 2, image 2 of 3 Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Depressurize the reservoir: step 2, image 3 of 3
    • Unscrew the cap covering the valve that regulates the internal pressure of the reservoir.
    • Using the screwdriver, push on the valve core to depressurize the reservoir.
  3. Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Unscrew the seal plate: step 3, image 1 of 3 Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Unscrew the seal plate: step 3, image 2 of 3 Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Unscrew the seal plate: step 3, image 3 of 3
    • Using a flat wrench (size 14mm) and a socket wrench (size 14mm), unscrew the 6 bolts holding the seal plate in place.
  4. Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Remove the seal plate: step 4, image 1 of 2 Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Remove the seal plate: step 4, image 2 of 2
    • Unscrew the connection between the head of the pump and the tank with a flat wrench (size 28mm or adjustable)
  5. Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Remove the reservoir: step 5, image 1 of 3 Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Remove the reservoir: step 5, image 2 of 3 Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Remove the reservoir: step 5, image 3 of 3
    • Unscrew the valve nut with a flat wrench (size 12mm).
    • Position the tank upright at 90° to remove the reservoir.
  6. Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Replace the reservoir: step 6, image 1 of 3 Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Replace the reservoir: step 6, image 2 of 3 Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Replace the reservoir: step 6, image 3 of 3
    • Put the valve back into the fastening tab of the reservoir.
    • Locate the valve's original spot in the bottom of the tank.
    • Insert the reservoir into the tank.
  7. Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Set the reservoir in place: step 7, image 1 of 3 Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Set the reservoir in place: step 7, image 2 of 3 Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Set the reservoir in place: step 7, image 3 of 3
    • With your hands, put the valve back in its spot inside the tank.
    • With a flat wrench (size 12mm), put the nut holding the valve back in place.
    • Position the lip of the reservoir on the outside rim of the tank.
  8. Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Put the seal plate back on: step 8, image 1 of 3 Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Put the seal plate back on: step 8, image 2 of 3 Replacing the Reservoir Membrane of a Sterwins Booster Pump (900W,  19L, 3800L/h), Put the seal plate back on: step 8, image 3 of 3
    • Reposition the seal plate on the tank.
    • Screw the 6 bolts back into place with a flat wrench (size 14mm) and a socket wrench (size 14mm).
    • Screw the nut between the head of the pump and the tank back into place, with a flat wrench (size 28 mm or adjustable).
    • Repressurize the tank to 1.8 bar max
Finish Line
2 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
iRobot
1 Reputation
636 Guides authored
2 Comments
Thank you so much for your tutorial. I am a window cleaner and it is a essential for me. After my pump broke last week I was planning on buying a new one but now its fixed because of you.
Neil Glass - Reply
Where can I buy the membrane?
Periklis Tsogkas - Reply
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 97
All Time: 5,679
